Author Topic: DC03 Absolute+- Beginnings  (Read 6558 times)
« on: November 16, 2013, 10:32:14 PM »
This worked its way into my car this morning from a vague facebook ad!
All the tools have the newer logo on apart from the crevice tool
I haven't had a DC03 in ages, and this one is in pretty good condition, and should clean up nicely. It runs well, has ok suction for now. lets give it a whirl
Oh..
Nothings happening on the carpet
Lets turn it over...
Ah
The belt is also nackered as I lifted it clear of the brushroll with 1 finger
snippy snippy
And it works much better now! Not fantastic, but its a good solid base.
Got this out of my mums carpets, so not all bad
It's now sat awaiting attention as the DC08 jumped the queue as I want to sell it.
Sat with its sucessor
And a DC05 Absolute+ I have
So, need to grab some new filters and new belts. Do these need special belts or would 04/07 belts fit?
And another nice addition to the collection.Almost tempted to keep the DC05 too and start an Absolute+ set, but I;m not sure yet.
Re: DC03 Absolute+- Beginnings
« Reply #1 on: November 17, 2013, 11:16:50 PM »
Clutch belts are the same, yes.
Offline absolutepurplelime
« Reply #2 on: November 17, 2013, 11:48:12 PM »
Are you doing to keep that 03 beko, I bet it will come up really good. Hope my de Stijl does :)
« Reply #3 on: November 18, 2013, 12:54:53 PM »
Yea I plan to keep this one. Need to start collecting Dysons before they become too rare and difficult to find a good one. Got some pictures to upload in a sec, you can see the whole sorry story. Glue will be needed though...
« Reply #4 on: November 18, 2013, 03:41:20 PM »
Well, after eventaully getting the DC08 back together, I turned to the DC03. Expecting a nice easy clean up, I was wrong!
Top washable filter was very manky. I did wash it, but I'm looking out for a new one, it didn't come clean enough for my liking, and the non washable bit was minging deep down
The filter housing was nice and clean though. Will give it a light polish before re-assembly
Stripped the wand off
And extracted the hose
Yummy, damp dog
Poked out
Split the hose assembly down some more
Did the ring of sealant come from the factory, or a previous repair? Kept it anyway!
The hose also has a split, if I can find my glue I will attempt to repair it, if not then new hose time!
Ah lovely, more ruddy plaster dust!
Removed the switch, and managed to snap one of the retaining lugs, more glue needed!
Dug the screw out to release the filter top/tool holder
And stripped it down
Top end done, I flipped her over
Much scrapage later and the damp layers of hair were removed. It is cracked in a few places, which should glue up, but the base plate part has worn down a fair bit by the weels so they now don't clip in, so it may need to be replaced.
Much fiddling later, it's all seperated. Makes more sense now I;ve done it how it works!
Clean clutch cover
Looking very odd now
Mint motor removed
Last of the air duct removed
Last but not least was the cyclone
Release valve was choked with dust
And voila, a pile of very dirty parts to wash
Pile of seals to clean and other random fixings
Misc
And the biggest jigsaw puzzle ever is awaiting re-assembly (as is the Turbopower which I still have not done anything with!)
« Reply #5 on: December 11, 2015, 07:31:46 PM »
Well, this little DC03 is still about. I've never been impressed with the performance with it, although it did work. The lack lusture performance was confirmed with the now-Mvacs DC03 Clear, which worked MUCH better
Even with the top chassis blockage cover fitted properly, it was still bad. I used it upstairs for a bit, then tore it down the other night to see if I could work out the issue
It's switch cover was pinched for the 03 Clear
Tools off
The Upholstry tool annoyed me
The hose was broken too, the clip to hold it onto the wand doesnt work
The wand cap spring is bent too as the cap flops around
Wand release button off
Top cord hook off
Hose released from the bottom
Hose removed from the changeover casette
I split the hose end
and noted that there were no little tiny springs present to enable the wand clip to work (it's never worked, I've never stripped the hose out before). The hose and filter (the filter was a silly idea as per my other thread) went into the washing machine
Hose seals out
Switch housing out
Unplugged
Removed
Top blockage cover removed
Seal out
The spinal cord can come out
Cyclone-Chassis seal off
The little passthrough seal is different on this one than the DC03 Clear, but peels off nicely
Pre motor filter holder comes out now
Filter top/tool holder assembly unscrewed
Little seal removed
Purple base removed, which revealed that the white inner was not positioned correctly
Filter holder seal removed
It looks like there is a seal missing from here too
Filter housing - chassis seal removed
Moving down now, the little clear window is removed from the cleaner head
The base plate comes off now. This doesn't seem to sit correctly at the front though, and I can't work out why that is
Split
Wheels removed
Brushroll out
and split
Wheels off now
The broken clutch cover can be unscrewed now
and removed, along with the soleplate seals
Clutch and bumper removed
The brushroll housing can be removed from the chassis now, and it seems one side of it is broken
The removeable soleplate clip unscrews
I think this is part of the changeover valve, either way it unclips from the back of the cleanerhead
and the changeover valve seal pulls off
Looking barer now
Motor housing off
motor housing side seal lifts off
The tiny motor can be seen now
Motor is spotless
armature not too bad
motor seals and retaining bracket off
The motor suction channel is held in with 2 screws
This releases the post motor filter housing, which just needs a clip squeezing to be removed from the machine
The spinal cable and remains of the sealing grommit can be removed  from the chassis now
The changeover valve seal from the valve to hose is removed from the chassis
The pivot plate for the side of the brushroll housing pulls out of the chassis
I went to remove the cup that the cyclone sits in, and it crumbled away in my hands. It had faded much more than the rest of the machine though, which weakened it muchly
The chassis is empty now!
Cyclone now
Bin and lower cone all stripped
top seal removed
Release clip removed
Cyclone screw removed
and cyclone bits withdrawn
Cone and Shroud split
Bin seal removed
Release valve cover falls out
release valve assembly unscrewed
seal out
Release valve split
all ready for washing
All was washed up, then the washing machine finished, and I learnt why DC03 Pre motor filters are not washable...
bit melted
bit broken
bit messy
Was like an explosion in a cotton wool factory, took fecking ages to vacuum up, and I had to clean the power head out on the Miele afterwards
« Reply #6 on: December 11, 2015, 08:08:07 PM »
All washed, dried and polished, I put an order in to Mvacs, who had me sorted out within an hour for Ła really good price!
So, time for back togetherness. Release valve first
Screwed up
Bin seal refitted
Release valve cover popped in
Cone and shroud meet again
Screwed up
Seal refitted
release clip clipped on
Lower seal on
Upper seal on
And the cyclone is done
The broken RH Pivot point slots in
Lower seal in
Spinal cord fitted
Lower filter cover fitted
Motor suction channel fitted
Motor wired up and fitted
motor housing seal refitted
Changeover valve brushroll housing seal fitted
The broken piece of the brushroll housing glued up very nicely
Random purple thing fitted
Baseplate clip screwed back down
Bumper and brushroll housing fitted fitted
Fitted the clutch
The broken clutch cover was screwed down
brushroll seals fitted
Wheels fitted
Brushroll fitted
Soleplate was reassembled
and fitted
Clear window fitted
Tool holder to chassis seal fitted
Pre filter housing seal fitted
slider assembly reassembled and sealed up (without the missing seal fitted)
sticky seal fitted
tool holder fitted
Pre filter holder fitted
chassis - cyclone seal fitted
blockage cover sealed up
and fitted
Cyclone fitted (minus lower cup)
That was it for Sunday night. It's been waiting for the Hermes man, who knocked on the door this afternoon with a box of goodies! So far, I have swapped the lint strips from the DC04 Absolute+ upholstry tool onto the DC03 Long nexk upholstry tool
and washed up the other bits. Hopefully later tonight, I can finish this off!
« Reply #7 on: December 11, 2015, 09:41:04 PM »
Didn't we send you a clutch cover? You mentioned fitting a broken one.
« Reply #8 on: December 11, 2015, 09:48:29 PM »
Yep,  just fitted that actually! Eating pizza,  then will crack on!
Online Madrat
« Reply #9 on: December 11, 2015, 10:07:25 PM »
I do like the 03 but my god the designer liked the rubber seals  :boggleeye: there seems like hundreds when you strip one
« Reply #10 on: December 12, 2015, 12:07:03 AM »
It's a very messy design with all the seals isn't it! Especially the changeover valve.
Anyway, I washed up the bits that Mvacs sent me, and finished her off after Dominoes and a few beers
The unbroken clutch cover was fitted
and the brushroll very carefully fitted!
The baseplate just doesnt seem to clip in at the front as well as I think it should. Warped floorhead?
The white part Mvacs sent me didn't have a seal on it either. Looking at the DC03 Clear pictures I dont think it had a seal on it either tbh. I fitted the Mvacs part as it didnt have the little dink in it the other one had
I found a too big seal
cut it to size and it pushed in and held around the perimeter of the white part
A smear of grease helped it all slide home.
I fitted the tools
Fitted the non faded cyclone cup
Sealed up the wand hole
Fitted the changeover valve
Onto the hose now. I found a broken hose end, and one tap with the hammer later liberated it's two speings, and fitted them to the DC03 hose cuff
Hose all clipped together, I wired up and refitted the switch
and fitted the switch cover
Wand back together
I fitted the wand cap spring from the broken DC03 Clear wand, as it wasn't bent. The cap springs as it should again
All done and back together, I gave it a quick test fire, and the suction is back again! And when you block the wand suction off it sounds blocked! The floor head seems to pick up better than it did too, but part of it's problem is it's just so light. Some weight on the floorhead would improve matters no end. It still picked up a fair amount from the rug in 3 passes too.
I'll vacuum the whole house tomorrow and see how it's improved in the real world, but initially, it seems to be fixed!
