That looks right, you can see the mouldings on the shell that correspond with the little tabs on the thermal cutout.As it is facing now, with the 'arrow' pointing towards the chassis it should fit into the moulding, the two mouldings should click together and it will rest home. Check there's nowhere the cable needs to be tucked through anywhere and voila!
Yes. We agree.
Correct pic is below. R
.... asleep?
