Author Topic: Motor Bench test Set up  (Read 4620 times)
Offline brett83
« on: June 25, 2014, 11:24:18 PM »
Would anyone disclose their set up for this as for the DC07 type motors I tried using clamps and the centrifugal force just detached if from the clams and it went flying across the room.
Thinking about designing some sort of jig / fixture.  What does everyone else use ?
Brett
Re: Motor Bench test Set up
« Reply #1 on: June 26, 2014, 08:10:26 PM »
We use a foot and the floor.  :underchair:
Offline premierdysonrepairs
« Reply #2 on: June 27, 2014, 12:30:22 AM »
 :biglaugh: :king:
« Reply #3 on: June 27, 2014, 08:18:23 AM »
I hold them, with the black housing seal attached, outside on the patio.
Offline brett83
« Reply #4 on: June 27, 2014, 01:39:43 PM »
I don't like the sound of that after launching one across the room.
« Reply #5 on: June 27, 2014, 01:43:20 PM »
I do make sure I'm holding it tightly and in such a way that my fingers dont get caught. If I did anymore of them I'd but a vice big enough to clamp the motor body in the test them, but I've held maybe 2 in my hand to test them, one was the one I rebuilt, one was slightly sparky but calmed down after a tickle with a comm stick!
« Reply #6 on: June 27, 2014, 06:17:23 PM »
A jig/vice type set up was always on the "to do" list, just never happened.
I also wanted to make a flex continuity tester that was a faster way of testing flexes in bulk than a multimeter (single socket on a surface backbox, 9v battery powered LED light drilled in, wired in such a way that you plug the flex in and the LED lights if there is continuity when the terminals on the other end are bridged).
Offline brett83
« Reply #7 on: June 27, 2014, 06:41:49 PM »
Mmmmmm sounds good. I'm might try and come up with a solution for both !!
Offline __russ__
« Reply #8 on: June 27, 2014, 08:41:49 PM »
Here's my rig - the plastic brush holder gets clamped in a vice and works perfectly!
« Reply #9 on: June 27, 2014, 08:56:56 PM »
Oooh I have a vice small enough to do that, great idea!
I have an old dc01 cable that I use to troubleshoot the cable on dead machines, quickly rules it out! Don't get that many dead dead ones though
