Turn it around and from the other end
yes. there is a piece of plastic with 4 fins on the bottom of the cyclone. One at a time pull hard and You'll feel a small click. Keep pulling on all 4 fins and the assembly will fall away. Then pull off the round holed shroud. You will see 8 rectangular holes. Blast them through. Then blast the rectangular hole on the side of the cyclone until you get clear water flow from all tubes.Job's a guddunYour'e not a Man U fan are you?
Btw, slightly off topic, but which types of homes have airing cupboards? I live in a terraced, Victorian house in Birmingham which was built in 1894, so 120 years old, and it doesn't have an airing cupboard. My cousins house has, but their house is in Rochdale, and is a semi detached property
