Author Topic: Dc24 main motor  (Read 2655 times)
Offline VacMine
Dc24 main motor
« on: October 28, 2014, 10:39:29 AM »
We have quite a few dc24's, however although they all have good suction, the motors make very high pitched noises, without the hepa in. A couple of them don't make the high pitch noise. When you put the bin back on you can't particularly tell there even is this noise. I have read something on this forum about a fan maybe causing this noise??
Re: Dc24 main motor
« Reply #1 on: October 28, 2014, 12:57:35 PM »
I recall it is the fan and/or the bearings that cause this to varying degrees.
We find ourselves changing quite a few DC24 motors now, and they are not especially cheap either.
Offline VacMine
Re: Dc24 main motor
« Reply #2 on: October 28, 2014, 01:17:19 PM »
Thanks for the response  :bow: can you change this fan? And would you say if they make this whistling sound (which nobody seems to mention) then the motor is knackered
Online __russ__
Re: Dc24 main motor
« Reply #3 on: October 28, 2014, 01:29:41 PM »
Due to their size, the DC24's are easy to block and invariably the dirt finds its way into the motor clogging the fan/bearings.
The whine means the motor is struggling and ultimately means it's not too far from  :dead-dyson:
Offline VacMine
Re: Dc24 main motor
« Reply #4 on: October 28, 2014, 02:53:22 PM »
Thanks for the advice  :thumbsup: we haven't had that much experience with the 24's. And there really isn't much on the forum about this noise.
Offline VacMine
Re: Dc24 main motor
« Reply #5 on: October 28, 2014, 05:55:48 PM »
Would a bit of wd40 on the bearings make a difference? :reading:
Offline Angus Black
    • Dyson Medic
Re: Dc24 main motor
« Reply #6 on: October 28, 2014, 06:41:34 PM »
Only if you are not selling it with a guarantee. Silicon based oil is better if you must oil something.
Offline VacMine
Re: Dc24 main motor
« Reply #7 on: October 28, 2014, 06:44:17 PM »
We'll break them then and use only the healthy sounding ones ;) thanks
Re: Dc24 main motor
« Reply #8 on: October 29, 2014, 08:12:21 PM »
You probably can split them, re bearing them, clean the armature and change the carbons but it would take hours, and I wouldn't feel happy unless I've been testing it daily in a machine for a week or so, then you would have to strip the machine again to get the motor out etc.
Put new bearings on a dc07 ydk and cleaned the armature before, that wasn't too tricky but your only one slip/swearword away from having a bad time!
