Author Topic: Lime and Silver DC04 Pre Motor Filter Clogging  (Read 2125 times)
Offline AliB
« on: January 22, 2015, 11:40:14 AM »
Hello
My DC04 pre motor filter is clogged solid after one use, what could be causing this problem, it doesn't look like its missing any rubber seals or o rings
Thanks in advance
Al
Online __russ__
Re: Lime and Silver DC04 Pre Motor Filter Clogging
« Reply #1 on: January 22, 2015, 01:47:36 PM »
Hello
Thanks in advance
Al
Have you got the bin insert sitting in the bottom of the clear bin?
« Reply #2 on: January 22, 2015, 02:11:09 PM »
There should be a thin rubber o ring at the bottom of the inner cyclone, and a rubber cap at the top that the inner cone seals onto.
Is also a rubber gasket underneath the main housing where the clear bin meets the top, but if that was missing you would have no suction.
« Reply #3 on: January 22, 2015, 06:56:03 PM »
Or is it inserted upside down?
