Author Topic: Dyson DC26 City Stripdown, repair and Refurb  (Read 27770 times)
« on: February 18, 2015, 10:42:54 pm »
A few years ago, my Dad bought a Dyson DC26 City. After a few months, he declared it utter rubbish, and relegated it to a cupboard and bought a Miele S7 which he should have done in the first place...
When my stepbrother got his own shell of a house and they moved in, he acquired it. He then used it as a shopvac until it didnt suck up anymore, and they banished it to a cupboard.
When we went to visit them the other week, his girlfriend threw this at me and kindly asked if I would remove it from the premesis...
So, it's been about a bit then...
Was also looking a bit sorry for itself
Put it in the car and came home
A few days later, I had a closer look
Mmmmmm I wonder why that's doing that...
I doubt that will wash up... Lets have a look at the pre motor filter
That picture doesnt really highlight how shite the filter was
Ah, this one does
Crap all in the fan blades
Surely the cyclone can't be that bad?
Yep!
Not even the hose escaped punishment
The cuff was so bad it wouldnt click on to anything
I identified that little problem straight away
The floor tool release valve was bunged up too
Of course, it needed saving, but (as we all know) there is NO information on the net about these. Spare parts are virtually non existant bar filters, so this was a bit of a dive into the unknown, with almost nothing to loose.
Almost... a fellow collector had expressed an interest with this, and a swap for a lovely Hoover Turbopower Boost. Steve, please read this before deciding, it's not in quite as good condition as I said it was after 3 pints of stella4...  :boggleeye:
So, with almost nothing to loose, here we go!
Couldn't really do much with the floor tool, so it got washed whole
Hose end next
The top cap pops off
and doesnt come off any more! I tried almost to breaking point and it wouldnt budge out the other end
There was a screw
but removing it free'd up nothing so back in it went and the whole thing got washed whole
Cyclone off
The hose is a bit deformed along it's length, has been walked over alot. It also doesnt come off easily...
Remove these three TINY screws
and the holder seperates and can be removed. The hose then pulls out of the machine
Delightful
Tools end is battered
red cap removed again
Onto the machine itself now
The housing pops off the pivot points
The inner holding ring is VERY difficult to get off, sounded like it was seriously breaking but didnt. Wheel then falls off
Filter release catch removed
Other wheel now
Was only a little bit dirty
Filter housing
Sadly, whilst untwisting the caps, one snapped  >:(
I swore a bit then carried on
Undo the screws holding the cord rewind cover on
I did the following in completely the wrong order as it turns out. What seems the correct way is:
Undo the screw
carefully withdraw the whole unit (cord wound up, so the springs not as tensioned)
leave it the f  :censored: k alone!
Mine wouldnt budge, layers of crud had stuck it all together, so I approached it slightly differently
I unwound the cable (mistake n.1), and prised the locking tabs off to remove this
I then lifted the springs out, and they nearly took my head off
 :censored:
Amazingly, they seemed to wind up ok
The clear plastic cap holds the rewind to the machine, so with that off the reel lifts out
it runs on these contact rings like a Numatic reel does
Happy 5th Birthday Dyson...In need of a full rebuild already...
This cap prises off and reveals the cord connections
which simply unplugs
One layer out
5 even TINIER screws and the cord reel back lifts out
and unplugs from the machine
The contact rings pop off the reel back
Moving onto the switch housing now. The cyclone release lever snaps out of the housing
The floor tool parking slot unscrews and snaps out of the housing
The buttons pop out from either corner
Sorry for the rubbish pics, the camera wouldnt focus...
Same for the cord rewind button
With a rather significant amount of prising and levering the housing pops up and can be removed
The switch pulls off the housing now
and the wires removed.
The switch - cord rewind can be removed completely
Back to the front of the machine now, and one screw on the top and one underneath release the hose input
This was so covered in plaster dust the flash bounced back
The next bit is very tricky. There are no screws holding the motor housing in, just large clips. So, 2 screwdrivers and some swearing, and it popped out with a large crack, and no damage luckily. There is a rubber tube leading to the post filter area too, which needs to be poked through as it goes.
The top cover came off as well, although the clips holding it on hold the motor into the housing so they unclipped on removal
There was a metal plate on the side of the housing
Ah, a comically large (for the size of the machine) PCB
The 2 motor wires disconnect from this board
The motor can be removed from the housing now
It's a panasonic
Fancase taps off
and a nut releases the fan and 2 washers
Another washer sits under the fan
2 screws seperate the bottom fan from the motor
and that's it! The motor doesnt come apart anymore!
Bit emptier now
There's a screw under the front to go
and the vent and very tip peice are removed
Onto the cyclone next
That's not flash glare...
Cyclone bottom flap comes off as per usual, and the outer seal pulls away
as does an inner seal
The top handle pops forward and off
Release rod pops out the top
4 screws enable the top cover to be removed
Another one holds the inner cap on
The inner seal sits below this
Now the inner cyclone was very interesting
Damn flash flare, I'm so sorry!
They all popped out, as did the middle 3 cones
The shroud and bottom cone seperated from the upper cyclones as they all do
And, she was stripped down!
Re: Dyson DC26 City Stripdown, repair and Refurb
« Reply #1 on: February 18, 2015, 10:43:58 pm »
This was going to be on one post, but surprisingly I reached the 25000 character limit  :D
All the parts were washed, the hose and pre motor filter went through the washing machine with some other bits the next night. If you drank your tea watching the stripdown, you'll need another for the re-assembly!
She hasn't come up 100% I'm afraid
Shroud still had residue in the holes
but it was as clean as it will ever get so back together the cyclone went!
Upper seal back on
Sadly the shroud split when removing it, only on one side though
3 Inner cones back together
and all the removable plugs back in the correct order. The black and white ones are moulded differently, so don't fit in each others holes
Top half looks better
and the middle screw went back in, followed by the lid and those 4 screws
Top handle was a pain to get back on, both the front and the back had to go in together, at different angles... was a lot of creaking plastic...
Inner seal back in
Outer seal back on
flap back onto the bin
Some damage to the bin now visible
and the cyclone is done!
sadly very cloudy and sandblasted
Onto the main machine now. Air vent back on
Some more damage unearthed now it's clean...
hose fixing plate snapped back in
Motor next, and I popped the carbons out and cleaned them up
Cleaned the motor up as best I could
First layer on
the fan was washed, scraped and de-clogged, and went back on
and then the nut and washers
The motor is one of these
The motor went back into the slightly cleaner housing now
rubbers on
back into the housing
I cleaned the PCB and thermal fuse up
byebye
mount for the housing fits into the chassis
This bit was tricky again. I couldnt get the motor housing back inw ith the 2 rubber mounts in place, so fitted the housing, then, using some oil, slid each mount into place. The third one was a pain...
all fitted!
This little sensor sits behind the hose entry port, and was buried under dust. It feeds through the chassis and into it's mount
then clips into place
Hose port clips back on now
Motor to switch wire was clipped into place
and fed the switch to cord wire through along with it
Switch back into place
Housing back on
screws and springs in
and the pedals
and the parking slot
cyclone catch was a bit more fiddly, but snapped in eventually
Cord rewind contacts were refitted
the wires were connected up, and fed through the support brackets
I started poking about with the release valve, which I didnt think came out. Turns out it does...
so I gave it a wipe down and refitted it. Then the cord rewind backing plate screws to the chassis
The cord guide goes onto the cord
https://lh6.googleusercontent.com/-ld3H7rqpeQw/VOTco5c6pZI/AAAAAAAAikQ/dMmUFOW4llU/s800/upload_-1.jpg
The cord plugs back onto the reel
and I refitted the old re-wound springs and top cap, and screwed it down.
Then the top half of the rewind
I tried to re-tension the reel, but no matter what I tried it wouldnt do it, so I checked that the motor ran nicely, which it did, and ordered a new rewind spring assembly, which seems about the only spare stocked by anyone...
Gave up on the cord and moved on to the filter housing
Button back on
The button is pocked too sadly, this machine's been rolled a few times I think
filter housing back on
The filter washed up REALLY well
so I fitted it for now. May buy a new one if I'm feeling flush on payday and I end up liking the machine at all...
I went to bed at the point (this was tuesday night), and when I got home from work today, I carried on.
New cord rewind spring had arrived
so I pulled the old one off (moving my head first this time), wound the cord onto the reel and fitted the new spring
A quick check of the cable confirmed good, if not a bit slow operation. The reel tensions itself up when removing the cord, I had to adjust the amount of pull though as the prings nearly pinged off their supports, so left a whole loop around the support pegs.
Satisfied that it was as good as it would ever be, I refitted the housing
had to give each ring a short sharp tap with the hammer on each of the clips to fit it...
Same on t'other side
Post motor filter now, and when I initially got it, there was a seal hanging off the surround for the output, which promptly fell off completely...
so I bought a Vax 121 bucket seal strip
and trimmed it to fit, and made a lovely new seal
A new post motor HEPA filter
slight difference to the old one
Managed to get the broken clip to turn home, so for now it's not a problem. If I can afford it on pay day and the machine deserves it I'll try and obtain a new door unit. It wont be the end of the world if it wont though, since the filter is shiney new
Hose now!
which had cleaned up really really well, and after some cif and microfibre action on the outside all the paint was gone.
Refitted the release catch
refitted the hose
fitted the handle
and she was finally done!
Eva tried it out when we were done, and her face says it all, it's not a brilliant performer tbh!
It doesnt feel like 1300w of suction, the floor tool feels like theres no suction at all on carpet, yet it glues itself to the lino in the kitchen. I don't think there's any air leakage on the machine, as when I block the hose off the release valve opens fine. Will remove the pre motor filter and see if it's killing airflow anywhere...
Had a quick play anyway!
Sounds a bit screamy, but after the battering the motor has taken already, I'm amazed it still runs at all...
Few more bits to do, and I'll investigate the seemingly poor suction too, it just doesnt seem as sharp as a 1300w motor should, My Hoover 417g is comparable, the Hitachi Powerhouse CV70D has sharper suction...
Hey ho, it's been fun to do!
« Reply #2 on: February 18, 2015, 11:53:40 pm »
Awesome strip down guide and photos!  :bow:
I have one of those 915219-03 HEPA filters on my desk at home to put on our site when I get around to it.
Edit: Now on the shop >>here<<
« Reply #3 on: February 19, 2015, 08:20:30 am »
I did check your sale page, but couldnt find any.
I went to move it this morning and the floro brush got caught in the parking slot, and the whole machine picked up too. Sod it, saved me bending over! It really is a tiny machine. Funky, but not terribly practical. Due to my height, when I use it and pull it about the front end lifts up and it comes over on it's rear wheels...
« Reply #4 on: February 20, 2015, 08:41:11 am »
Mmmmm, I thought somethign was amiss but I don't think it is...
In use, there's a loud howling from the machine. At first, I thought it was just the motor being a bit knackered, but if I remove the cyclone the noise stops and the motor sounds lovely!
Intregued, I stripped the cyclone apart again just to check. All was well...
Opening the pre motor filter cover stops the noise
Removing the filter and closing the door again and the noise re-appears
Could it just me that the sirflow paths are so tight on this machine that the airflow is causing the howling noise somewhere? There's no leakage, the noise doesn't stop if I squeeze the machine whilst running.
Anyone else got a DC26 who could confirm or deny there is an odd noise with the cyclone in place and that the noise stops when it or the pre motor filter cover is removed?
Offline dragoncurt
  • Dyson FTW !
« Reply #5 on: January 24, 2018, 07:04:29 pm »
Hi, just got one of these today and I've read the part when you said the hand pops off from the cyclone but I'm not able to do that. Do you mean the back where the red bin label is or the front where it shows Dyson. Thanks
Offline leoyang123
« Reply #6 on: February 06, 2022, 10:51:28 am »
Hi Beko:
   Tks for your Awesome strip down guide.
   Can you teach me how to remove top handle from DC26?
Tks
Leo
