Author Topic: Pre-filter keeps blocking  (Read 6275 times)
Offline dsam
« on: March 20, 2015, 11:34:15 pm »
Hi, does anyone know why the filter blocks up after about 4-5 uses, it seems to be sucking to to much dust and fluff threw the cyclone onto the sponge filter. Ive swaped the cyclone unit with another 1 and it doesnt block up so its definately something to do with the old cyclone, power washed clean to no avail.
Re: Pre-filter keeps blocking
« Reply #1 on: March 21, 2015, 04:45:57 pm »
Check the rubber ring at the bottom of the cyclone.  It will probably be split or perished letting the dust through onto the filter.
Offline dsam
« Reply #2 on: March 22, 2015, 05:40:00 pm »
tried this and was ok, even changed it with another 1 and still no joy.
« Reply #3 on: March 22, 2015, 05:57:20 pm »
Is the cyclone leaking at any of its joints. Look for a hissing from the middle of the cyclone when running.
« Reply #4 on: March 22, 2015, 06:50:58 pm »
The noise that comes from a DC07 would you be able to hear a hiss ?
« Reply #5 on: March 22, 2015, 09:28:56 pm »
Run a small bead of silicone around the middle joint if it's leaking air. Did the top handle seal refit correctly when you took it off to wash the cyclone?
« Reply #6 on: March 23, 2015, 12:54:56 am »
Its challenging I know, but we had one recently leaking there on test after refurb. It just didn't sound right and performance was down. It took a few minutes of testing, but we found the hiss in the end. After a new cyclone it was golden.
« Reply #7 on: March 23, 2015, 12:41:18 pm »
I always give the top seal a good spray of silicone polish to make sure it sits properly, if there dry they are almost impossible to get back together.
Offline dsam
« Reply #8 on: March 23, 2015, 01:05:08 pm »
I think were veering off topic, the suction is great no leaks. The question was why does hoover pick up ok but drag dust and fluff through to the pre-filter? In my eyes can only be the fdc seal at bottom of cyclone (which is fine) or the cyclone itself.
