Author Topic: Vax 121 - Stripdown and Refurb  (Read 30325 times)
« on: July 12, 2015, 11:41:08 pm »
I got this little gem a few weeks ago. A very, very mint Vax 121
The exception is the dusting brush, which was truly battered...
It had the bag holder. I found a Hoover 375 belt to go on as it was missing its one
The wet tools have never been used!
There is 1 watermark on the solution tube, which is very annoying as it's mint otherwise!
The machine itself
One of the motor bolts had vibrated out, all the others were loose too...
Filter was quite dusty
Genuine Vax bag fitted
Sadly, it didnt come with any extension poles, so I grabbed 2 of those from the shed, and a boxed automop I happened to have! And some bags
My helper helped me check that it worked
and I got started on the stripdown!
Hose first
Hose trim pulls off revealing 2 locating tabs
which pop out and seperate the hose
The hose went through the washing machine very nicely indeed!
Filter next
Cartridge seperates
A big seal sits between the parts
I attempted to revive the dusting brush
but after 20 minutes of pulling and teasing got nowhere, it is ruined.
so onto the main machine
bag had split...
Recovery bucket was quite dusty, these single walled bags dont hold the dust in the best!
The wheel housing slides off the bucket
The wheels pull off the pegs
and the pegs stay in, this part is obscenely brittle when it wants to be...
cable off
The 4 bolts come off the bottom
This is the secondary filter for the motor housing
This screw comes out of the switch cover
The cover has the LED attached to it
which is fixed by one of those horrible spring clamp things, so I left it on there
Orange switch cover falls out
There's a retaining ring that holds the switch in
which again, was loose
Bolts out (loose...)
The springs fall off
Next, get your long extension bar and socket set
and remove the handle bolts. Again, finger tight on this...
2 bolts removed, the top half comes off
These wires are all in the back of the switch.
Split the rest of the plastics
A bit carboney, nothing too bad though
This is the supressor
held on with a bolt
7mm
and once removed, I snipped the black wires off
Feb 1990
The blue wires got the snip too
Wires to the switch
Made in England! I dont think there's a single part on a modern vax that's made in england now!
The cable clamp assembly comes apart now
All removed
Motor now
The main chamber lifts off the motor
NOT an ordinary vacuum cleaner...
This metal spring was present too. Must earth it somehow
The motor was mint, I dont think this machine has EVER seen water tbh
it was so clean I left it alone, just blew the dust off and wiped it down.
Next, the old seals were removed
Onto the next batch of parts now!
I bought this Automop a while ago for my old Vax, so it has been used, hence it went through the motions
The sponge pulls off, held in with friction only
This plate directs the solution to over the sponge
The squeeges pop out
and the rubber slides out of the carriers
This revealed some screws
This peice of I presume steel sits at one end of the automop, presumably to provide some weight to help it flip
The neck has a seal and diverting cap on it
Wash tool now
Which splits out nicely
Crevice tool didnt need any stripping down!
Upholstry tool looks pretty mint
Bit of dust lurking though
The bag adapter even needed some stripping
Small head
Only the black insert comes out of it though
I left the solution tube be, I;d onlyu make it worse with watermarks I couldnt get out!
Orange joining peice looks good, not perished at all!
The float valve pulls apart
Removed the seal from the solution tank too
Never been used possibly at all, certainly not in anger
Naked
These next
Poles got a wire wooling as they are a bit more used than the vax, cleaned up nicely though
Floor tool came apart as it was a bit dusty
I then noticed a sticker on the solution tank. Odd. Removed that anyway
Sorry, back to the floor tool. Baseplate off
Lint strips out
Tiny bit of fluff under the brush cartridge
Minty
Locking module removed
Pedals out
and off
And she is stripped!
Everything was washed and dried, and then the plastics were polished!
Not bad for 3 hours with the rotary!
Re: Vax 121 - Stripdown and Refurb
« Reply #1 on: July 12, 2015, 11:41:17 pm »
Assemblage time!
Randomly, there is a bit of damage to the recovery tank, looks like something hot or solventy got sucked up once...
Motor nestled back onto the lower mount
Metal clip refitted
Time for electrics now
The wires that used to go to the supressor were crimped and heatshrunk together
Hat on
I then realised it was MUCH easier to put the black handle on first, so top cap as well, then feed the wires through that, as the handle wont slip over the housing with the wires poking out
Once everythings plugged in (IIRC, the switch has the 2 blue motor wires one side, and the first set of spades from the wiring block. The second set of spades then connect to the LED)
Float valve back together
and I got out a new seal
Floor tool next
Tiny bit of damage sadly
Onto the filter now, and the first thing I did was get the iron out...
It's SO much easier to refit the filter when it's flat!
and another new seal was fitted
I'd put the machine together with the solution tank after fitting the new seal overnight to secure the seal adhesive
So had that off, and fitted a paper bag
Back together with the hose, which was washed along with the filter and some other hoses and filters in the washing machine
Cleaned the hose to machine seal
and gave her a test run!
and she sat in the corner for a day or two
I bought something for it, which came a few days later. In that time, I got 2 layers of wax on it, and on sunny friday afternoon, took some after shots in the garden
I bought a new dusting brush for it, happened to be one on ebay. Sadly, the logo is a different style, so have left the old one with the machine to keep the originality. The bristles will swap over, but I'll leave that to the next owner to see.
She's on ebay now, it was always going to be a restore and sell project, but you dont see many this clean or complete nowadays. I have a used twice, in the box with all packaging 121, and this isnt far off the same condition tbh, very very few dinks to mention! Still, the 121 always holds a special place in my heart as Mum had one, and Granny too when I were a lad, so I'll never turn one down. Hopefully this one will give someone years of enjoyment to come!
« Reply #2 on: July 13, 2015, 01:47:40 am »
That Vax looks well good, you did a fantastic job as usual! ;D :thumbsup:
Also, the bags look a bit unusual, I thought they used the ones like the 6131 or something, IIRC my cousin's 121 they had used a cloth bag but it was the same design as the 6131 where the collar slides into the grooves with the hose off  8)
« Reply #3 on: July 13, 2015, 03:44:34 pm »
It uses both types. I think their originally came with the cloth bag, my Gran still has hers. This fitted to the bag adapter, but you can also get open ended bags (basically massive hoover junior style) that fit onto the adapter.
The other type has the collar built in, and I think fit the recovery tank better.
Wish there were hepaflo type bags available though, would sort the filtration out a treat, maybe coupled with a cut up henry hepaflo bag to replace the cheesecloth filter...
« Reply #4 on: July 13, 2015, 07:56:00 pm »
We have the later, upmarket version of that in dark green and orange, it is fitted with a pump for the cleaning solution.  Always had great suction.
« Reply #5 on: July 13, 2015, 08:41:55 pm »
Ah yes,  they had higher wattage motors and the later pleated filter!
« Reply #6 on: July 13, 2015, 10:47:51 pm »
That's it, variable power as well.
Offline Tech12
« Reply #8 on: July 14, 2015, 08:09:34 am »
Nice write up, but why did you remove the suppressor ?.
« Reply #9 on: July 14, 2015, 10:16:35 am »
I've had them blow on me before, as have other collectors. Same with Electrolux 500 series cleaners with the supressor in the handle, they always go!
I had a dirty jobs vax from the car boot sale years ago (about the time I got my NIB machine) and the supressor went on it whilst I was vaxing the front room. Killed the power to the cleaner, then filled the flat with a burning plastic smell, which I got told off for on her return...
The supressor had blown, then melted. I've helped save a few other 121's as well by talking the owner through how to remove it and reconnect the wires. I just didnt think it would make a great impression when the new owner of this one opens the box, plugs it in and it chooses that precise moment to go CUL8R and pop...
I tend to remove them as habit now. Their not needed unless you happen to collect old radio's and TV's as well, and it's one less thing to go wrong. I've seen the big Hoover Senior ones go, they make a bang, and coat everything around them with black, which means you need to strip the machine down again to clean it up! The E lectrolux 500 series, some of the models have the supressor in the handle, where you hold it to use, I've heard that causes great* hilarity when that goes pop and your holding it!
Offline Tech12
« Reply #10 on: July 14, 2015, 12:59:54 pm »
They're not needed ?. I think you'll find they are, Manufacturer's don't go to the expense of fitting them for the fun of it. The interference caused by an unsuppressed motor can affect a lot more than Vintage radio, yes they do occasionally go pop but not that often. As for Vintage appliances I'd be Replacing the filter as a matter of course, before turning it on. Trust me, filtering & suppression is there for a reason.
« Reply #11 on: July 14, 2015, 02:08:00 pm »
That's the one, it's a bit battered now I sad to say  :underchair:
« Reply #12 on: July 14, 2015, 02:17:43 pm »
As much as you probably know more of the technical side than me, in practise I've removed tens of them from machines, in many cases bringing the machine back to life because of it, with no ill effects. Same with many other collectors who have a vintage machine go pop on them!
Would c ertainly never advocate removal to hide another problem though, and of course the new wiring connection must be sound, especially in a machine such as this which may see water around the motor at some point in its life...
Offline Tech12
« Reply #13 on: July 14, 2015, 04:15:35 pm »
Sorry, but whether you or other collectors have removed them to repair a machine is immaterial. They are there for a specific purpose & should be replaced not removed or bypassed. I've known a lot of collectors over my years in the trade & other interests & they'll go out of they're way to put an item back in an As Original condition.
Offline Tech20
« Reply #14 on: August 22, 2015, 03:18:27 pm »
Tech 12. I'm more than with you on the replacement. Its there to prevent electrical motor noise being conducted back onto the mains and although there may be no noticeable effects to the user their neighbour may be thinking otherwise. Mine has just failed after a few decades and my problem is for the vax 121 sourcing a replacement. I may have to find a chassis mount filter an bolt that in but they tend to be larger.
