Author Topic: 1980's Bendix 7159 Washing Machine  (Read 25812 times)
Re: 1980's Bendix 7159 Washing Machine
« Reply #30 on: August 18, 2015, 07:14:03 am »
Never mind, I appreciate you looking.  I will order one from Germany, £28 with postage.  Might need a stiff drink by the time I finished with the German web site, I didn't do German at school, I had to do French  :angryman:
Achtung Bitte! Google Chrome is your friend. Auto translate.
« Reply #31 on: August 18, 2015, 12:14:45 pm »
 :D
Wish I had known that, I was using firefox and a translator in another window, took me 15 minutes to fill in the order  :duh:
« Reply #32 on: August 21, 2015, 03:00:24 pm »
I had a delivery today from Germany, it's the seal for the Bendix compact.
Do you think the English postal/courier service has a bad name?
Defiantly well packaged.
 :thumbsup:
Offline Tech12
« Reply #33 on: August 21, 2015, 03:10:37 pm »
Nice, sorry I couldn't help out. Let's hope it does the job. ;)
« Reply #34 on: August 21, 2015, 03:18:48 pm »
I will be trying it out soon, just had a nice lunch and catch up with old work friend at the local Italian and I'm a bit stuffed and unable to bend in the middle,  :sleepy_man:
Offline Tech12
« Reply #35 on: August 21, 2015, 03:48:50 pm »
Aah the strenuous life of the idle rich  ;D :underchair:
« Reply #36 on: August 21, 2015, 04:16:27 pm »
Ha.. I bloody wish  ::)
Just tried it and not a dribble from anywhere.  Always nice when there's no dribbling  ;D
« Reply #37 on: August 21, 2015, 04:42:57 pm »
One, early 80s Bendix compact in mid cycle with no leaks.
Just needs a clean up and grease inside and a bit of a re spray.
Will be coming to Cornwall with us in the caravan next year.
Offline Tech12
« Reply #38 on: August 21, 2015, 05:09:32 pm »
Excellent, another golden oldie saved from landfill :thumbsup:
Glad there's no dribbles ;) you know you've had too much Vino, when you start to dribble  :icon_nod: :biglaugh:
« Reply #39 on: August 21, 2015, 05:11:50 pm »
Nice! Never got washers tbh but good yo see it working!
« Reply #40 on: August 21, 2015, 05:43:32 pm »
Just boiling, then I will strip and apply the grease  :boggleeye:
 ;D
Offline Tech12
« Reply #41 on: August 21, 2015, 06:20:48 pm »
 ;D
Now now, none of your kinkiness please. I'm too young to hear about those things :))
« Reply #42 on: August 21, 2015, 07:08:27 pm »
Lol
« Reply #43 on: August 21, 2015, 10:55:22 pm »
OK so I've had a play, but first a bit of history.
The Bendix Compact was actually made by Eudora in Austria, and was called lots of different names throughout Europe, it's very well built but quite different to most other automatics.  The drum is fixed and has no springs or shock absorbers, The motor is an induction type with a variable belt pulley that control's the drum speed, probably why the spin speed is only 550rpm, but also why it is still going strong.
Info plate.
Top off
Back off
Surprisingly clean for a 30 -35 year old machine.
The motor and variable pulley.
This assembly is driven by a cam on the drum shaft and drives the program knob round, not found on other automatics but can be found on some twin tub's
This little gizmo is what stops the machine spinning if the drum is out of balance.
Just look at the size and engineering of that water pump,  puts today's crap to shame.
The drain hose is starting to crack up, not bad for its age though.
This was never going to be a full strip, so I just brushed out the dead spiders and fluff, and got to work with the 3 in 1 and a tub of grease. All done, switch on and...........  :censored:  has someone given this thing an E or something, its gone crazy  :o  It did a wash is 3 minutes and didn't even give the water time to get warm before it went into rinse  :snivel:  Top off, back off head scratch.  Ahh sorted, as the belt pulley adjusts the motor also rises and falls on a spring loaded pivot, it was stuck in the high so fast position, a quick poke and hey presto. Its also much quieter, the program mechanism used to tick away like and old clock, not now.
Sorry had camera up the wrong way, I am blond after all  :duh:
Will post video of motor and pulley moving later as I have developed a dribble  :censored:  :'(
Offline Tech12
« Reply #44 on: August 21, 2015, 11:21:49 pm »
Told you to leave the vino alone  ;)
Nice solid machine, you won't get today's crap lasting like that.
