Once you see the satisfaction that a nicely soldered and heat shrunk joint brings, you will never go back. You will be flashing stranded wire with solder to wire plugs even.
Stu: Your out of date (Sorry couldn't resist it ) .
Quote from: Tech12 on September 14, 2015, 07:20:05 amStu: Your out of date (Sorry couldn't resist it ) .I am going to go back to using KitKat tinfoil on fuses now.
A cut down 6" nail works well
