Author Topic: Replacing/obtaining motor Supressors - Knowledge me up!  (Read 50753 times)
Offline Tech12
Re: Replacing/obtaining motor Supressors - Knowledge me up!
« Reply #90 on: October 19, 2015, 07:55:10 am »
If the Blue wire is the Live & the Black wire is the Neutral then there's no problem. Basically the filter just fits in parallel with the mains, but it needs to be as close as possible to the source of interference for best effect.
That's a pretty neat solution  :thumbsup:
« Reply #91 on: October 19, 2015, 08:51:10 am »
The blue wire is crimped on with a brown wire and comes from the switch.  Theres 2 black and 1 red from the cord reel,  one black goes to the motor and one goes to the pcb, and connects to the same ring on the cord reel so I assume its neutral,  one red goes to the pcb then a red out to the switch on the other side and the red that clips onto the motor.  I presume the pcb steps the live voltage up and down as needed by ots command then?
At the hospital now for the last appointment before the baby is here,  will plug it in tomorrow.
Got 5 hoses,  4 filters and a load of my polishing pads in the washing machine at home too,  hopefully that will finish clattering around by the time we get back!
Offline Tech12
« Reply #92 on: October 19, 2015, 09:23:35 am »
Hope everything goes ok ;)
« Reply #93 on: October 19, 2015, 04:08:55 pm »
Thanks Tech!
Just need the hose for the white one to dry, and the potentiometer to work on the purple ones hose when I pick that up in the week and 2 out of 4 dolphins will be restored!
Offline Tech12
« Reply #94 on: October 20, 2015, 10:37:31 am »
Did you ring David Casson about a switch ?
« Reply #95 on: October 20, 2015, 10:48:57 am »
Nope,  not yet
Offline Tech12
« Reply #96 on: October 20, 2015, 01:07:59 pm »
No probs, let me know how you get on ;)
