Author Topic: My first DC04 Zorbster!  (Read 12065 times)
Re: My first DC04 Zorbster!
« Reply #15 on: September 10, 2015, 10:31:07 PM »
Or you can do away with the micro switch thing and use the normal TOC.
Online __russ__
« Reply #16 on: September 10, 2015, 10:49:24 PM »
Yes. Only the TOC is different but that is just swapped from the old motor.
 :thumbsup:
« Reply #17 on: September 10, 2015, 11:25:02 PM »
Yes but then you cant use the zorb feature.
Online __russ__
« Reply #18 on: September 11, 2015, 08:44:50 AM »
True but then I've never come across anyone that has used it anyway  :))
« Reply #19 on: September 11, 2015, 10:27:04 AM »
I want to use it! (Mainly because I NEVER have before!)
« Reply #20 on: September 11, 2015, 09:46:06 PM »
Its wicked, it halves the voltage of the motor! ;D
Online __russ__
« Reply #21 on: September 12, 2015, 05:35:57 PM »
To be fair, if anyone was ever going to use it, it was going to be you   :biglaugh:
« Reply #22 on: September 12, 2015, 05:38:22 PM »
Hehe thanks! At least if it does turn out to be a pile of toss I can say I tried,  and bave an opinion if anyone ever asks me about it again!
« Reply #23 on: September 12, 2015, 09:24:45 PM »
You should be alright :) My DC05 motorhead looked a bit complex cos it was already taken apart with the previous owner, but managed to get it working optimally by guessing how the wires go, that's old Dyson's for ya! they are too easy;D
« Reply #24 on: September 22, 2017, 01:26:58 AM »
How old is this thread? Well guess what I finished tonight... Refurb images coming soon! (Although not a full step by step, just an overview with detailed shots of the zorbstery bits!)
« Reply #25 on: November 20, 2017, 12:02:23 AM »
So, here we are! I've had this since 2015, and a month ago I cleaned it all up! This thread isn't a full step by step refurb, there's plenty of those on these forums!
So this will concentrate mainly on the differences between a DC04 Zorbster, compared to a normal DC04 All Floors!
I finally did a 'before' video
Not a valid youtube URL
It came in from the cold
I stripped the wand down
Opening the switch up, someone has been here before!
Hardly surprising though! Popped the cable out and removed the rubbers
I don't think I've seen this style of airflow guard on the suction side on a DC04 before. Could be wrong though
Changeover valve inspection pipe out now, and oh look, it's blocked!
Split apart
Post filter cover off
Clutch knob off
« Reply #26 on: November 20, 2017, 12:08:48 AM »
The U bend clip is broken sadly
Underneath now
Baseplate off
Brushroll out, it's VERY soft, which is a shame because it's purple!
The first physical difference! The brushroll chamber within the brushroll housing is more round than usual, with the moulding used being different
Next, I went to pull the clutch out, as I usually would at this stage, but could not move it
So I popped the whole head off
And found the second difference! There is an extra part off the side of the clutch!
This part has a slightly offset cam on the end, which is what shakes the cleanerhead when the Zorb hopper is fitted, shaking the powder out of the machine! With the hopper not fitted, it doesn't touch anything, so doesn't shake.
It's seen belts at some point, these are I think Europart ones with that DBB number
« Reply #27 on: November 20, 2017, 12:15:57 AM »
With the clutch out, we can see the third big difference, the Zorb hopper securing gubbins!
This chunky pedal is what clamps the hopper to the machine. It just pops out, and has a big spring underneath it
This part is what the clutch shakes!
Back to normality now! Changeover valve out
Wheels off
I've lost count of the differences now, so another one is that each rear wheel has a thick rubber scraper, presumably to de-clag the wheels during a good zorbing session!
So, the next step on a DC04 at this stage is to remove the motor, but it would not budge with all the screws out. This leads us to another difference, the 2 speed switch, which annoyingly on mine has been glued to the chassis
Some considerable screwdrivering later had it released with only some damage
« Reply #28 on: November 20, 2017, 12:22:45 AM »
For the first time in ages, the rubber seal that seals this to the chassis was not perished!
And now we come to the big difference, the gubbins that controls the dual speed!
This is the switch that sits behind the glued in part. When pushed in (bin on) it's full speed, when released (bin off) it drops the motor to half speed
It all sits in this bracket that screws onto the motor housing
There we go, 250v/120v. I wonder if you could plug this in in america with the bin off and it would run at full speed?
The switch all comes apart nicely anyway
Now we come to the main event, the utterly trashed motor!
I don't think a drop of oil and a fan wash will help this much, it's totally  :dead-dyson:
We need this little red wiring loom though
« Reply #29 on: November 20, 2017, 12:26:19 AM »
All that heat (and I imagine actual proper flames) had given  the inside of the motor housing some lovely patina
Main machine done, the cyclone assembly is a bog standard job, just in purple, so bin cone and seals out/off
Top part split up
Upper cone removed
Release valve split for washing
And it's apart!
Everything was washed, polished and laid out, so here is EVERY part of a Dyson DC04 Zorbster!
And we start with the motor! Wires put in
DC04 Spare Parts
