Author Topic: DC21 (Canada) Stripdown?  (Read 7428 times)
Offline Myron
« on: October 06, 2015, 07:21:13 pm »
I need to strip down a DC21.  (I suspect a wiring issue for the electrical supply to the power head.)
One machine screw is accessible next to the cord-rewind button, and a second is under the top filter.
There must be more screws holding the cowling in place. It seems likely that they are under the two large wheels, but I cannot figure out how to get the wheels off.
There is no screw in the centre of the wheels, nor is there a "hub cap" that pops off to reveal the screw.
Each wheel appears to be made as a single molding, although I cannot be certain of this.
The wheels may simply press on over a slight bump on the axel, in which case you just have to pull them off.
BUT . . . I don't want to break anything by forcing something not designed to be forced.
Have any of you taken this type of wheel off??  Suggestions?
Thanks.   Myron
Re: DC21 (Canada) Stripdown?
« Reply #1 on: October 06, 2015, 07:46:33 pm »
Do you have the first three digits of the serial number please so I can cross check it with our models?
Offline Myron
« Reply #2 on: October 06, 2015, 08:59:20 pm »
First part of serial number:  383-CA
Offline Myron
« Reply #3 on: October 06, 2015, 09:28:22 pm »
My basic problem is that the power nozzle worked perfectly for some years and then the next day it simply did not work at all.
A friend's same-model power nozzle did not work on my machine, either.
The Canadian distributor sent me a new hose, but that did not help. (I have not had a chance to try it with my friend's nozzle.)
There are three electrical connections in a straight-line plug.   If I call them 1, 2, and 3, I measure the following voltages:
1 & 3 = 0 volts
1 & 2 = 38-42 volts
2 & 3 = 58-63 volts
« Reply #4 on: October 07, 2015, 05:36:50 am »
So for the gurus here, this is a motorhead machine in the DC08/DC19 family. So how to remove DC08/19 wheels is the first question.
Offline Tech12
« Reply #5 on: October 07, 2015, 07:56:34 am »
Looking at beko's DC08 write up, the wheels pop off with the aid of a large screwdriver.
« Reply #6 on: October 07, 2015, 11:30:23 am »
Yes, a long screw driver shoved in then prised off, it shouldn't break but makes is scary as it does sound like it. There are 2 screws behind each wheel IIRC from my DC08, one behind the pre motor filter aswell
« Reply #7 on: October 07, 2015, 01:45:20 pm »
I just grab them and pull.
Offline Tech12
« Reply #8 on: October 07, 2015, 01:47:03 pm »
« Reply #9 on: October 07, 2015, 05:34:04 pm »
The Op was asking about wheel removal, not dating tips Madrat...
« Reply #10 on: October 07, 2015, 05:37:39 pm »
Lmfao ;D
« Reply #11 on: October 07, 2015, 05:37:56 pm »
I wouldn't want to go on a date with you  :o
« Reply #12 on: October 07, 2015, 05:42:09 pm »
Haha imagine what would Mrs Madrat would do ;D
« Reply #13 on: October 07, 2015, 07:48:32 pm »
1 & 3 = 0 volts
1 & 2 = 38-42 volts
2 & 3 = 58-63 volts
AC or DC?
You are on 110-120v there, yes?
