Author Topic: Electrolux Dolphin Z2260 Electronic 4x4 - Repair and Refurb  (Read 2932 times)
« on: October 23, 2015, 07:44:01 PM »
I have had this vacuum cleaner for 3 years now. Bought on a whim on ebay, it came with a broken speed control on the hose. The day it arrived, I attempted to take it apart, and broke the hose even more. Ever since then, it's sat at the back of the loft awaiting the day some motivation came.
I found myself with 4 dolphins last month, and nearly got one down, but got this down instead, having been here the longest.
First up was to get the hose working. Hindsight showed me how to remove the locking tab on the hose correctly...
Along with my other dolphins, I had a few spare hoses, and the locking tabs are set up to take the power connectors that were never fitted, so I took one off, and took the remains of the lavendar one off the broken hose
You can see the remains of the locking tab still fitted to the hose
Removed the remains
Old v new
The contact strips pop out
and fit to the new tab
The other part of the contacts sit on the hose, and sprung bits of brass join them up
Some re-bending of the brass tabs to provide good contact and the new locking tab locks on
This is the machine in question
It's been repaired before by the looks of it
You can see the tabs on the machine side under the cover
So, the hose worked for the first time since I buggared it all those years ago...
Woohoo! Even Amy cheered (mainly because I then stopped pissing about with it at 11.45pm...)
So, next issue, which tech helped me with massively in the supressor thread was the speed control
This was the original issue, why the machine was being sold in the first place (and the owner has a bloody impressive amount of vacs and had a clearout, but it's stayed in the fold), the speed control doesnt work
I broke this open back in the day, and never did get it working again (dry solder was the original issue I think)
I broke the remains off the board, and had a look
A layer of something wasnt there to provide the contact, lost forever in 2 house moved
I went on an ebay hunt, and found some new potentiometers.
The day after I ordered those, we had massive network problems at work, and those of us who can work from home were told to do one at 10am. After the best damn drive home I've ever had (a naughty 25 minutes door to door 20.3 miles away), we were told to not log on, as IT had to prioritise the VPN connection for payments.
So, I had a look at the machine
The tools were wankered, the dusting brush and upholstery tool (had been squashed at some point, crack marks all over it) went in the bin
Tool tray is fine
This bag would have come with it when I bought it, knowing Richie god knows how old it is!
Filter was well past it too
2 rubber bungs flick out of the hose entry housing
The bag door comes off with a push of the tabs
The decal was loose anyway, so off it came
Underneath, the bag fill indicator is held on with hot glue
Seperates out easily
3 screws and the hose input housing comes off
Not a valid youtube URL
Hose power connector sits under here
Marked up for reassembly
Bag door seal pulls out
The wires run under the seal, and enter the machine here
The bag holder flicks off 2 shallow tabs
The bumper unclips from all around the edge
The exhaust filter should sit under here, it hasnt had one for years
The power decal pretty much fell off with a prod
Under 3 more screws sits the best damn circuit board I've ever seen on an oover
More reassembly markings
the 1400w (oooooh) boost button lifts out
hose wires removed
Extra bits removed, 4 screws come out, and the whole thing lifts out
Lovely
bye
The rear wheels sit on a keyed tube with a peg inside to stop it opening on its own
One had some string around it
The bag door latch is held on with a screw
I checked in with my boss at this point, who said still no word, and they were down the pub still... righto
Wand park slot unscrews from the inside
Front wheel has the only phillips screw on the WHOLE machine
Front wheel sits on another keyed plastic rod
Little balancing wheels pop out too
I dont know if this seperates anymore, I dont think so as you can see melted plastic joins, so I left it at that
Much wow
I didnt dare twist this screw...
One white wire runs to the switch, the other into the motor. The red from the motor plugs in behind them. Red runs from the cord rewind to the switch
Ah look, a black.
Apart
I left this well alone after that, sod trying to trace a fault with it, that would be a massive thread of questions
Cord reel now
Tug the side of the housing out and unclip the axle
Red to the inside, black to the outside
Translation - DO NOT F*CK WITH
The cord ends looked in good order
The cord reel guide had an obstacle in the way
I won
The pedals flick out of 2 retaining tabs
sprung by 2 metal springs
This was interesting, and may explain the repair shop sticker. On/off pedal had to be held in place with a bent hook of metal
Moar cobwebs
Aha, a screw holds a little latch on
Switch lifts out
There's a seal that goes between the motor housing and bag housing
4 more screws
And a motor
It sits in a keyed recess
Motor seals off
Wires connecting up to the motor
This sticker fell off the motor
The top comes off the top of the motor by releasing 2 clips
This has seen some dust then...
The carbon brush holders snap out of the casting. The carbons wouldnt fully remove themselves, so I cleaned them up as best I could
That's as far apart as it goes
Just a big rivet
And that is that stripped down!
Got to wrap this up for now, will start with the rebuild  later, dinner is calling!
But, an interesting story...
Was quite chuffed they replied. So it's an oirish vac!
Re: Electrolux Dolphin Z2260 Electronic 4x4 - Repair and Refurb
« Reply #1 on: October 23, 2015, 11:22:40 PM »
I masked it up and got the rotary out
If you look really closely you can see where it was masked up
You cant see it in normal situations though. Motor next. The minging top cap was brushed off, some oil introduced to the top bearing and the carbons refitted
Oil was dripped into the fancase bearing, which smoothed the whole thing out. and it was re-assembled
Top (or bottom, depending on how you look at it) motor mount fitted
fancase seal on
Motor fitted
Housing lid screwed on
seal refitted
Switch fitted
lid screwed down, and spring refitted
Power pedal fitted, along with historic repair
cord rewind side
Luckily the wiring sort of falls into place
PCB fitted
Front wheel re-assembled
and fitted
Bag door latch fitted
Parking bracket fitted
Rear wheels fitted
« Reply #2 on: October 24, 2015, 12:34:41 AM »
Looking cleaner!
Plug refitted
but not until the cable was refitted to the guide
and secured with its screw
Wires to the front run
bag chamber seal fitted
Stuff plugged back in
Cover plate refitted
I hadn't dug about in the shed for consumables yet so just refitted the filter cover
Contact block fitted
Cover fitted
plugs fitted
The bag full indicator clipped in perfectly fine without any hot glue, so I left it at that
Some new glue ready for the decal
Tool tray fitted
The bag latch was left off as the bag door wont shut without the bag in place with it fitted
Done!
Onto the floortool now. Had to hunt around in the loft for this, was properly buried
The back plate unscrews
The spring for the brushes pops out
brushes lift out
Front litter picker was dead
Floor change pedal snaps out of its housing
Front wheels fall off their axles
Rear wheel hammers out
Another rod hammers out to release the pivot joint
Whilst that dried after being washed, I dug some genuine filters and bags out the shed that I've had for years
The first filter
Secondary filter
Bags
Crevice tool back in
Post filter
Floor tool was dry by this point
Metal glider caps back on
Pivot pin back in
This bottom pin stops the whole thing flipping around itself
Rear wheel in
Changeover pedal fitted
cleaned up brushes fitted
brush spring fitted
Fitted
Suction channel fitted
Brushes up!
Done
I then tested it worked ok, Eva helped too
Even Charlie got a vacuum
Nearly Done!
Whilst some of the above was going on, the new Potentiometers arrived, and my stepdad soldered one onto the handle circuit board for me
It is different, as the adjuster wheel doesnt sit as it should, but isn't 'adjustable' due to the position of the adjuster on the pot, so it will have to do!
However, it does work! Can be a bit slow to change the motor speed, but it seems to get a bit more adjustment with each use, so maybe it needs to be bedded in.
Either way, it works well enough!
I found a matching dusting brush and upholstery tool in the shed, so they got fitted. The crevice tool is still on the DC16, wherever that is! Dead chuffed with this, the Dolphin collection has begun!
Offline Mig
« Reply #3 on: May 31, 2018, 02:42:42 PM »
Hello, I have a Dolphin 1400 too (Z2260). Any ideas where I can get a motor from?
Offline oldmoley
« Reply #4 on: May 31, 2018, 09:56:20 PM »
All of this is persuading me to haul my Mum's old Dolphin out of retirement. She had it from new. Hasn't been used since she passed away 15 years ago, so should be interesting! I remember the wand control died quite early on, so it has the same problem as Beko's had, at the very least......
