Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Miele Vacuum Cleaners
Miele SAB-100 Accu Nova Power Head
« previous
next »
Print
Pages:
1
2
3
Go Down
Author
Topic: Miele SAB-100 Accu Nova Power Head (Read 9507 times)
RustySkull
Member
Country:
Gender:
Kirby, Royal, Sebo =)
Re: Miele SAB-100 Accu Nova Power Head
Reply #30 on:
February 09, 2016, 07:55:38 PM »
Get a Lipo and a nice Balance charger, you'll have the fastest brush ever haha
Logged
Twitter
dysondc16
Member
Country:
Gender:
Reply #31 on:
February 10, 2016, 12:42:03 AM »
I'm not doing anything to it that beko hasn't done to his! LoL
I really can't wait to get it running, but I will have to
Logged
beko1987
Member
Country:
Gender:
Let's take it apart!
Reply #32 on:
February 26, 2016, 06:56:04 PM »
I had this apart the other day, after using it as part of the big clean of the house we did the other week. It got very overwhelmed by all the hair, and I didn't use it much
First step, safety first, remove the battery
Undo the base plate screws (which don't come out, their moulded into the baseplate
Remove the baseplate
The 2 small front wheels pop out of the base plate
The brushroll lifts out of the unit
and slides out of the belt
The brushroll bearings slide off the ends of the brushroll
Next, pick all the hair off
Much better!
6 screws remove the top cover
Which holds the power button cover, and the clear plastic LED lenses
The power button cover pops off it's hinge
The lenses pop out of the housing too
April 2004?
Logged
beko1987
Member
Country:
Gender:
Reply #33 on:
February 26, 2016, 06:56:41 PM »
Onto the next layer
This spring sits under the power button cover
Another matching date stamp
The battery power connector lifts out of the housing
The battery connector doesn't need to be unplugged to get the middle section out, but I did...
Onto the bottom layer. The switch and motor wires run under the middle under a plastic cover
I started with the motor, and marked the wire location
Motor markings
The motor is held in place with this end cap, which fits a moulding in the main chassis
The belt will have fallen off by this point
Power switch next
Switch removed, I moved onto the suction inlet, which has 2 metal bushes where it all pivots
The surprisingly simple PCB is next
This spring holds the battery tight (well, the original battery, it's not so good with the bojack one)
The bumper all but falls off at this point too
This is the hole that monitors the suction, it connects to the PCB via a molded tube
Removed
This part controls the second part of the sensors, and detects motion on one of the wheels
Empty
Last thing to come out is the rear wheels
The one that gets picked up by the motion sensor has a metal insert
And stripped! There's not many screws
Logged
beko1987
Member
Country:
Gender:
Reply #34 on:
February 26, 2016, 06:56:58 PM »
Everything was washed up along with a DC07 I stripped first
Rear wheels in first
PCB back in
Wiring fed across to the other side. This is a fiddly part, as the cover doesn't 'snap' in, so gets dislodged very easily
Battery holding spring fitted
Suction inlet fitted
Power switch fitted
Motor fitted
Middle cover fitted, as well as the battery terminal block
Top cover was reassembled and screwed down
Back underneath, and the brushroll is refitted
Baseplate refitted
I put a few winds of tape around the battery, which holds it in much better
Quick test, and it works
And back in the hallways it goes!
It works better than it did before, wether that is a placebo effect or not, but it grooms better than it did! Maybe the brushroll benefited from a wash!
Logged
dysondc16
Member
Country:
Gender:
Reply #35 on:
February 26, 2016, 11:42:50 PM »
Well now it looks far too nice to use! Looks like you'll just have to put it on display.
In all seriousness it does look fantastic now. I still need to get a battery for mine.
Logged
beko1987
Member
Country:
Gender:
Reply #36 on:
February 26, 2016, 11:45:38 PM »
Oh I couldnt do that, its so lovely to use! As long as I can clean it back up to this state Ill keep using it! Are they as cheap on ebay us as ebay uk?
Logged
dysondc16
Member
Country:
Gender:
Reply #37 on:
February 26, 2016, 11:48:01 PM »
The only one I saw recently was the one I have now. It didn't have a battery or charger which likely lowered the price and put other people off. I got it for just over 40 U.S dollars delivered, so less than 30 pounds.
Problem here is that they hardly ever crop up!
Logged
dysondc16
Member
Country:
Gender:
Reply #38 on:
February 26, 2016, 11:57:26 PM »
Speaking of which, just did a quick search on ebay and found a brand new one without the battery or charger for about 50 dollars, free shipping.
Oh well, I'm happy with mine!
Logged
Print
Pages:
1
2
3
Go Up
« previous
next »
on
