Author Topic: Bought a Faulty DC25 on eBay - Advice Please?  (Read 9944 times)
Offline ASHMAN123
« on: January 09, 2016, 07:08:04 pm »
hi room I just purchased a Dyson dc25 hoover off the seller kayysmithh on ebay. The item works but there is a part missing that transfers the suction from the head of the hoover to the wand it operates the movement  of the hose to the wand. does any body have any suggestion as to what part is missing or am idea of where I could find the info I need. thank you very much Ash.
Re: Bought a Faulty DC25 on eBay - Advice Please?
« Reply #1 on: January 09, 2016, 09:03:45 pm »
Hi ash.  Look at the cleaner from the front,  then look at the left hand side.  The suction runs through a pipe that moves.  Or,  the lever that is operated by inserting or removing the wand,  behind the cyclone.
Put some pics up if your unsure and we can advise
Offline ASHMAN123
« Reply #2 on: January 09, 2016, 09:48:25 pm »
how do u add image
« Reply #3 on: January 09, 2016, 09:49:33 pm »
Press reply at the end of the forum but before the quick reply box.
Or if you have an image hosting account you can img tag link them
Offline ASHMAN123
« Reply #4 on: January 09, 2016, 09:58:44 pm »
I think its right image
« Reply #5 on: January 09, 2016, 10:02:35 pm »
It's a zip file,  but shows that there seems to be something missing,  mainly the changeover wheel.
Head over to the dc25 section,  find my rebuild thread a d see if you can spot the difference!
Offline ASHMAN123
« Reply #6 on: January 09, 2016, 10:04:47 pm »
how do I get to ur link
Offline macman
« Reply #7 on: January 09, 2016, 10:06:56 pm »
« Reply #8 on: January 09, 2016, 10:10:54 pm »
No,  the clear cog that pushes that hose about
https://manchestervacs.co.uk/DysonForum/index.php/topic,1060.0.html
3rd  pic down,  on my phone so can't direct link it.  Just looks on yours that the lever that drives the changeover wheel is just sat on its own
Offline ASHMAN123
« Reply #9 on: January 09, 2016, 10:12:52 pm »
cant seem to see item
Offline ASHMAN123
« Reply #10 on: January 09, 2016, 10:17:41 pm »
beko1987 im missing that clear disc / cog what is that item called
« Reply #11 on: January 09, 2016, 10:18:38 pm »
There is a clear wheel type part that connects up to the lever that gets moved when you insert and remove the wand.  This connects to that move able hose on the left.  It's missing a part.
If you can get a pic of the whole machine I can confirm,  or open the thread I linked to,  look at the 3rd pic and you will see a see through part that you don't seem to have
« Reply #12 on: January 09, 2016, 10:19:23 pm »
Sorry,  was typing/drinking beer when you replied.
Yes,  I think so.  Mvacs can send you one,  but what else are you missing....
Offline ASHMAN123
« Reply #13 on: January 09, 2016, 10:22:52 pm »
I think it is the only part missing so If I can get link will buy new part.
« Reply #14 on: January 09, 2016, 10:27:11 pm »
If you look at this other listing of hers
http://m.ebay.co.uk/itm/301832903528?_mwBanner=1
And zoom right in you can see it.
Chaps,  what's the part called? Changeover cog? You'll need the screw and washer type plastic thing to go with it though...
