Author Topic: JohnsonDiversey Ensign SM2  (Read 9514 times)
Offline RustySkull
  • Kirby, Royal, Sebo =)
Re: JohnsonDiversey Ensign SM2
« Reply #15 on: February 11, 2016, 09:29:38 PM »
My G1 went in the skip at work this morning... Had enough.
« Reply #16 on: February 11, 2016, 11:26:16 PM »
Well, I drove to a lovely part of Buckinghamshire... then turned left and into the scummiest estate I've been in for a while! (right by HMP Bullingdon) and picked it up
Luckily, it seems ok
No bag fitted though
And the bag door closes without a bag in which it shouldn't do...
Crap picture but 2006
Looks like a tiny bit of damage to the bag holder
Brushroll looks ok. A few tufts are damaged, but overall it's fine
The blockage door doesnt seem to sit flush though
Post motor filter is filthy
5 minutes with a small brush de fluffed the spring and pivot point and it closed again
Popped into the shed and got a new bag out
The bag door latch doesn't sit flush with a bag fitted, although people who know SEBO more than me say they've seen this before and it's generally ok
Properly chuffed for 10!
« Reply #17 on: April 23, 2016, 10:24:07 PM »
So, I had this apart the other night!
The hose had gone through the wash previously, hence not fitted
Blank screw card
Handle off
Undo the screw, and pull the handle up slightly. Then, pull the inside part up and out (outer/top part wont come out yet)
The mains cable sits under the clamp, then the inner cores clip to the clamp
Bye!
The mains cable is held into the switch with screw terminals
The mains cable pulls out of the handle when unscrewed from the switch
Neutral and a black wire sit on one side of the other side of the switch
Switch unwired, it pushes out from behind
With the cables unplugged, the other part of the handle pulls out of the, erm, handle!
The little black cable goes down to a tiny ring, which sits under the handle to earth against the metal part
At the other end of the handle is the socket, which is held in with a small tab
The terminals didnt want to let go, so I left them
Handle done, I took the suction tube off, and couldn't find any way to get it apart so left it whole!
This bit didn't move
So I took the bag compartment off the motor head and started on that.
I've been using it loads, even to clean out other minging, blocked vacs (it's got 2 dc07 cyclones of crap in it ontop of everything else) and it's still only half full! Buggar all suction though
Next is the bag release mechanism
The best way I found is to pop the orange tabs out at the top and slide the grey part out the bottom
The piece that stops the bag door being fitted if there's no bag unclips and withdraws from the frame
It has a small spring
There's a cover on the inside of the bag door latch that unscrews
This is where the bit I have no idea where it goes came from, the small metal piece at the top...
Anyway, the filter is removed
Sadly, breakage happened. I didn't know it came apart on one corner, tried to flick it off with a screwdriver, and snapped it. So I'll need a new one of those...
The top inner part of the bag housing has the hose entry port, and the bag holder on the other. It pops and wriggles out
There's a rubber seal
and a peice of metal that isn't a spring
We can see where the spinal cord runs now the top piece is removed
It's only held in with the removed piece so falls out
The top 2 cable camps unscrew
3 screws release the lower cord hook
It 'latches' around its rotation using a metal spring that sits inside the inner piece
Time for remove the piece of metal that stops the machine being used with no filter
One screw!
Sitting underneath the bag housing is the plug for the lower join of cable, held in with 2 screws
But the terminals didnt come out of the housing, so back up to the top
A bit of pulling
and removing the bottom cord clamp
and the cord withdraws from the bag housing
Some screws underneath here now
and with considerable effort the lower bit comes away from the bag housing
The release button lifts out of the housing
There's another rubber seal under here too
The 2 tool clips snap out of the housing
Done
Time for the main unit now!
we are at this stage with the screws
Old post motor filter out
Brushroll out
Empty!
Bit of a build up under the rear baseplate
2 screws release the hood
This piece of sound deadening sits behind the post filter
The Electronics are much simpler than I imagine the auto height ones are!
Thin ribbon cable
and it unscrews
The brushroll release button lifts out of it's holder
The springs were a bit filthy
More sound deadening under the top cover
Le motor
A little cover covers over the pivot mechanism
The belt goes over the spindle underneath a cover
The support for the bag housing falls out of it's locating hole very easily
The motor unplugs and lifts out
Looking a bit barer now
Rear wheels now, they are held in with 3 metal tags and screws
I popped one of the wheel caps off to see what was what, saw one of those horrible spring clamps and put the cap back on...
The release pedal unclips from the wheel axle
I unscrewed the smaller, rear PCB now
Here is the other end of the ribbon cable
and the other end of the motor cable
These cables disappear inside the pivot assembly
Which unscrews at the front, unclips from the back and removes itself from the main motor unit
PCB fully unplugged
This vent hole was a bit blocked
A plastic ring pulls off the sub chassis
The blockage/bag full sensor sits here
Let's start stripping it down!
The very top bit holds the contact pad, with the rest of the assembly holding the sprung unit
I did attempt to remove the electrical connectors, but they wouldn't come out so left them be
Where are we?
The socket within the pivot assembly pops out and the wires pull out
and the wires pull out of the socket to aid re-assembly as the angled connectors were a tight fit
Another spacer ring
It took me ages to work out/remember where this bit came from, it's the dooberry that pushes the height adjuster wheel right down when the machine is upright
The height adjuster knob wiggles out around the bar
Flipping the machine over, there's a cover that covers the centre wheel axle
The cover also holds the little orange trapdoor in place
The wheel car convelutes out of the chassis
Nearly there! Belts and cogs next
This was really cool, it's sprung, I presume to stop the brushroll coming to a dead stop.
Brushroll drive cog
Bumper off
Front metal baseplate off
Each brushroll protecting bar pops out
it's finally EMPTY!
« Reply #18 on: April 23, 2016, 11:16:48 PM »
Washed, polished and laid out for a picture!
Time to go back together! Starting with the brushroll protecting bars
Whilst washing it, I found out that there is another little bit of bumper that comes out
so it and the main bumper went back in
And then back out on one side as it is easier to fit the brushroll cog
and then have it out again to fit the belt...
sprung cog and belt next
Centre wheel and axle fitted
I then showed Autovac my snack
The tabs holding the axle on are different. It's obvious which is which though
This is a part that I skimmed over on dis-assembly
it sits here
Height knob fitted
Orange flap
and the cover
This L shaped bracket is where the spring goes for the centre wheel ram
Let's make a start on the pivot assembly, one of the black rings in
Wiring fitted
There's a little clamp for the wiring
Bleed valve/led sensor now
Fitted
Little wires fitted, and pulled back on themselves to hold them in place
and fitted, with the wires tucked away
and all locked down with a black bit
Foam fitted
and the end mount fitted
Let's get some wires on the PCB
Other side mount fitted
Pivot assembly fitted and screwed down
PCB Screwed down
Rear axle now, and a tip I found is to fit it with the spring like this
So it's tensioned against the chassis
and screw it down. This is where I realised that the locking tabs for both axles are a different size, and guess which ones I fitted incorrectly... Quick swap round and...
I then worked out where this bit sits
When the machine is moved upright, this bit on the pivot housing pushes the ram down, bypassing the height adjuster mechanism and lowering the wheel to raise the brushroll off the floor
Motor fitted
Belt fitted to the motor
Stabiliser bar and belt guard fitted
motor housing fitted
Brushroll release fitted with cleaner springs
Wires routed properly
This is how it senses that the brushroll is jammed, there's a motion sensor sat on the end of the PCB
Slightly cleaner sound deadening fitted
Cover screwed down
Plastic base plate part fitted
Brushroll fitted
End cap fitted
Post filter cover fitted for now
Done!
Getting through it!
Tool clips
Rubber seal fitted to the bag chamber
Bag chamber release fitted to the bar
Fitted
2 Halves fitted together. Make sure the metal spring sits against the metal bar to push it against itself
Spinal wiring fitted
Fitted
and fitted at the top to stop it flopping about (oo-er)
oops, screw back out
Aha!
Lower cord hook fitted
Top suction channel fitted, with rubber seal
and a foam seal that sits between the bag chamber and this part
done!
Bag door next
cover fitted
No bag no closey widget fitted
positioned at the bottom of the track
and slid up until it snaps into place
Handle now! cable'd up
Earth cable fitted
The spinal cable is a bit tricky to feed up the tiny hole, and needed some tiny pliers to pull the terminals out
Switch fitted and half wired
Cable fitted into the handle
Handle put together
Switch cover fitted
So, the machine is done, now it is finally tiem to get the goodies out I bought in Feb!
Nice new post motor filter
Lovely!
More battered than I would like, but a lovely new service box
Shiney!
Fitted!
A lurvely ultra bag
and the bag door is fitted, the batch doesn't quite sit quite flush though annoyingly
I bought some tools too!
as well as a dusting brush clamp from sebo
Fitted!
There we are, 97% done! I'll buy a new hose clip, and buff her up and do an after video. I've had a quick play, and the suction is sooooo much better than it was, even with an empty bag! Then it's up for sale!
« Reply #19 on: April 23, 2016, 11:24:46 PM »
very nice! Theres a G1 for sale near me on Gumtree ;D
Now that the suction is better, I remember you said the DC75 cinetic cleaned better than this, so does that still apply now this Ensign has been refurbed? :thumbsup:
« Reply #20 on: April 23, 2016, 11:27:15 PM »
:o What are you using now? Gonna buy another Sebo?
« Reply #21 on: April 23, 2016, 11:33:52 PM »
I reckon it would be a close call,  the 75 would probably pip it due to the beating tbh,  but we will never find out cos theres no way I'm taking it back to that hose now it's clean! Next step is to sell it!
« Reply #22 on: April 23, 2016, 11:38:10 PM »
Cool ;) You will probably get lots of ERP cheap balls in like 5 years time like there are DC25's cheap around now
Some reason my DC41 Mk2 bristles look worn but still beats, I think its because we have rugs and have tile flooring underneath the rugs so might stress the bristles out
« Reply #23 on: April 24, 2016, 01:43:02 AM »
Awesome strip down topic!  :bow:
Offline RustySkull
« Reply #24 on: April 29, 2016, 11:35:58 PM »
It didn't really, my sense of humor doesn't go very well in this forum I don't think lol.
I still have the G1, it's in the cupboard ;)
« Reply #25 on: April 30, 2016, 12:19:50 AM »
Gosh :))
Offline RustySkull
« Reply #26 on: April 30, 2016, 12:22:47 AM »
And still broken.
« Reply #27 on: April 30, 2016, 01:34:03 PM »
Yes I know lol :|
Complex looking bugger to fix your sebo problem with sadly, not to say it's impossible because it's gotta be something
