Author Topic: DC25 brushbar problem  (Read 12062 times)
Offline ade555
Re: DC25 brushbar problem
« Reply #15 on: February 19, 2016, 10:56:17 PM »
All easy to fix, but inspect the pedal and its attachments carefully before you order parts, easy to miss a bit you need.
well it looks like the parts are there just can't see where the spring has to go, I'm sure is the one to pull the red pedal up when you locking the hoover in upright position
« Reply #16 on: February 19, 2016, 11:18:25 PM »
Ah, maybe check it's not an easy fix. Look up my refurb thread, it will show you but there's a tiny spring inside one end of the red pedal, and a big chunky spring from one end of the grey wheels part to the side of the ball area.
The red pedal doesnt really move, it's the grey pedal, when you push the red pedal down to recline the machine, it enters the right part of the notched bit it has, the grey pedal then springs up taking the red pedal with it. Same when you push it down to stand it up and lock it
Offline ade555
« Reply #17 on: February 19, 2016, 11:38:57 PM »
Oh you had to started now this will bug me all night  :))  just had a look and it looks like one of the spring that is attached to red pedal in your pic 36/37, now just need to figure out how to get that in there
« Reply #18 on: February 19, 2016, 11:47:14 PM »
you cam get away with just taking the red pedal off,  undo the 2 correct screws and pop the ends out,  then pull the wheels back as far as they will go (near vertical with the back of the machine)  and the red pedal shoild slide out,  I did this with a dc24 the other week, their vaguley similar  machines...
Offline ade555
« Reply #19 on: February 20, 2016, 10:04:50 AM »
Well I decided to strip and clean everything, all back together now is well  :thumbsup:, refitted the pedal spring now just need to get the brushbar sorted.
I did find on ebay complete unit at 40 anyone had experience with them? looks a bit waste just paying 30 for motor when you can get original head for extra 10, but I notice there is 2 different part number some are listed and ending with -01 and the other -08 number
« Reply #20 on: February 20, 2016, 11:08:54 AM »
i dont know about the part numbers, but yes, sometimes you have to weigh up if the extra tenner for a new shiney housing is worth it, and it will be simpler than fitting new internals to an existing case!
The parts could be the dame, and Dyson just changed the part numbers mid run but I'd wait for someone who knows what they are talking about to comment before splashing the paypal just yet
Offline theheadschoice
« Reply #21 on: February 20, 2016, 10:31:00 PM »
another update, got the motor running as the neg wire was a bit loose, motor sparks like hell but it turns so that would rule out the PCB for 100%?
Nice result but lucky this didn't blow the pcb  :))
^THIS! You did get very lucky! Once you notice a section of that copper missing, you know it's toast. or if they're a bluish black.
Congratulations on lucking out, ade!
« Reply #22 on: February 21, 2016, 09:24:19 PM »
Ours are 27.99 inc delivery in case of need.
915499-01 was the original part number, 915499-08 is the superseded part number. The units are the same.
Offline ade555
« Reply #23 on: February 22, 2016, 04:38:22 PM »
Thanks for info, I went with complete unit as I don't know how old is the PCB and will need new end cap is well.
Offline ade555
« Reply #24 on: February 25, 2016, 05:32:33 PM »
brushbar fitted and works like dream  :thumbsup:
