Author Topic: Washing machine F13 fault.  (Read 3132 times)
Offline Dockie
« on: March 29, 2016, 10:37:08 PM »
Hi I'm from Dundee and o have a cr01 that's 13 years old and I'm needing some help with a f13 fault
Offline premierdysonrepairs
Re: Washing machine F13 fault.
« Reply #1 on: March 29, 2016, 10:52:10 PM »
F13 is heater or thermistor fault, i.e the heating element is faulty or the thermistor is not sensing the heat.
Offline Dockie
« Reply #2 on: March 30, 2016, 12:04:27 AM »
Hi
When I stripped the machine down I found the neutral wire from the element was melted Along with the terminal. Also the terminal corroded.
What would cause this??
« Reply #3 on: March 30, 2016, 12:08:09 AM »
Terminals some times burn if the wire is not secure when it is crimped, through time the heat going through the connection causes it to burn off, have you remade the connection with a new crimp?
Offline Dockie
« Reply #4 on: March 30, 2016, 12:12:10 AM »
Yeah
I've striped the wire back and put new wire the same gauge with a new crimp on the end and the machine Seems to be ok now but I am running it with the front off as I had a leak which turned out to be coming for the drum drain to the coin trap. Which I have cleaned up and resecured with two cable times instead of one.
« Reply #5 on: March 30, 2016, 12:16:53 AM »
That is good news that you have got it working again, these machines are a bit thin on the ground now.
Offline Dockie
« Reply #6 on: March 30, 2016, 12:45:58 AM »
I'm totally gals it's fixed as I love the machine plus I want to make sure I get my 1000 worth out of it!! But then I've had it 13 years lol
