Author Topic: Hoover Turbopower 2 U2106 - Stripdown and Refurb  (Read 2887 times)
« on: May 02, 2016, 02:10:09 AM »
I won this some time ago on ebay for just over 5. Came from a nice elderly couple, owned from new etc, just what all us collectors like to see
Whilst tidying the shed, I found my Permabag 2, Hoover's first generation bagless collection system, cobbled together when Dyson started to take over the market. I've had this for years but never used it, so thought I would refurb it along with the machine, mainly to get it out of the shed!
The only thing to come off the bag door is the retaining latch
The lid comes off the permabag
This blurry shot shows the inside is filthy, and going mouldy after god knows how many years in a garage and shed
The inner box slides out of the cage, showing the years of dirt that have seeped through, apparently the system was, for want of a better word, shit!
But I'll keep it as a bit of nostalgia!
The pre motor filter was a bit clogged
I had already washed the hose, so the cable came off at the back
as did the small tools
The handle is removed with one screw
I did as I was told and left this label alone
The switch housing is removed with 2 screws
which exposes the wiring
The switch cover pops off
and once the bag full light is removed the little red lens falls out
Everything was de-wired
Crap picture, but the bag holder unscrews
and the two lower bag chamber screws are undone
The lower trim piece is levered carefully off
and the 4 motor cover screws are removed
and the cover lifted off
the 2 really long screws sit at the top
The post motor filter sits under the black cover
Inside the motor housing sits a diffuser, which had disintegrated as they all sadly do
With the motor cover out of the way, and the screws undone the bag chamber lifts out of the main chassis
revealing the motor in all it's filthy glory
The main suction channel lifts out first, along with the little pipe that connects to the pressure switch that drives the bag full light
The pressure switch pops out of it's place on the chassis
Back to the top, the main wiring is held in place with this horrible clip, which I did not bother to replace
Once removed the wiring can be removed from the machine
The next step is to remove the height adjuster knob
and rotate the machine over
The clear blockage channel unclips, and 3 screws removes the base plate
There was a bit of smeg buildup by the belt
4 screws release the hood
revealing some date stamps, and allowing the bumper to be unclipped
The release pedal unclips from the hood
I removed the motor at this point, although this could have been done before moving onto the hood
The big rubber fancase seal falls off
and all the wiring is removed
2 clamps either side on the pivot points are removed, one side is metal, the other plastic
This little piece of rubber sits in the motor housing on the back chassis
The belt spindle end holder and rubber seal
The choc block is removed from the chassis
and the carry handle, lower cord hook and tool holder is released with the 2 remaining screws
The release mechanism pops out of the lower chassis
I did not remove the rear wheels, as replacing the circlip looks damn near impossible with my motley collection of tools, do I did not enter that world of pain
The middle wheels are held in with this hateful spring clip
Which is easily removed, but also easily broken
The height stepper block splits and is removed once the wheels are out of the way
Main machine stripped, it was time to look at the brushroll
The end caps were full of fluff
Whilst all this was going on, I soaked the permabag assembly in a bath full of hot water and dissolved washing powder
and then rinsed it off and soaked it in a bath of hot water and bleach to sort out the mould
The rest of the machine was washed, dried and polished, and then re-assembled
Motor in
Ducting replaced. When I finished, I noticed there was no suction, I hadn't clipped the top duct into the fancase properly, so make sure it snaps in fully
I didn't take step by step re-assembly pictures, but  the rear tool holder was fitted, then the bag chamber, then motor cover, then lower trim piece
Wiring and bag full gubbins fitted
The lower chassis was re-assembled and the hood fitted
Activator brushroll re-assembled with fresh bearings
and a new belt that came with the machine
I found some new filters in the shed
and checked out the clean and dry permabag
All the staining has gone, which is good
New post filter fitted
A week or so after I picked the machine up, the previous owner messaged me to say they had found the manual and guarantee, and would I like them? I said yes please, and went and picked them up, which is great as now I have a very complete TP2, the only way it could be better is if they had the box!
With the machine re-assembled, I had a vacuum with it
it seems to work very well as this is what it picked up after that video
This rug is vacuumed regularly with the Miele AccuNova, but the AccuNova isn't a very deep cleaning head
I then went up into the loft to get the red TP2 out for a bit of a photo shoot
and then put them up in the loft for another day
Happy to have this one, I feel the TP2 collection should grow a bit, they are very very good cleaners, better with a proper paper bag fitted though!
Re: Hoover Turbopower 2 U2106 - Stripdown and Refurb
« Reply #1 on: May 02, 2016, 01:01:27 PM »
I quite enjoyed reading as usual ;D
This Hoover thread was interesting for me, I know what a Permabag is now and I thought it was a pointless plastic cage for the bag so it wouldn't rip or something! :|
I would like a TP2 now, along with a TP1/Junior I think that would be really cool. I like the red one you have, think it looks great :thumbsup: Not triedone so I;m not sure what the performance it's comparable to
« Reply #2 on: May 02, 2016, 09:48:31 PM »
How long dose it take for the bag to clog?
« Reply #3 on: May 02, 2016, 10:18:12 PM »
It seems fine still,  but ive been told not long,  then it's a pig to clean and needs another vacuum to do it.
I had a hoover discovery with the same system once,  and that clogged up really fast. If I ever need to use this in anger ill pop a proper bag in!
