Author Topic: HOW do you do remove circuit board & hi low switch in a henry  (Read 6404 times)
Offline ClassicDysonDealer
HOW do you do remove circuit board & hi low switch in a henry  and just run it on full 1200w all the time
can some body help poor old henry
Re: HOW do you do remove circuit board & hi low switch in a henry
« Reply #1 on: June 07, 2016, 09:35:11 PM »
« Reply #2 on: June 07, 2016, 09:35:38 PM »
« Reply #3 on: June 07, 2016, 10:18:52 PM »
You remove the PCB and wire straight to the switch!
You need to strip it down quite far, but basically:
Undo the 4 outer screws, flip back over and lift the hat off. lift out the cord rewind unit and remove the little wheels (or watch if they fall out
Pop the cover off that covers the switch and wires behind the switches and unplug everything.
Flip back over and remove the 3 inner screws, then pull the (now top, was bottom) off.
You'll now see the PCB, remove all that and it's wires. You will be left with the L&N from the cord rewind, and 2 white wires from the motor.
Put the bottom/top on with the 3 inner screws (I fit the sound deadening inside the case thing then slip that over the motor, then place the motor rubber on top)
Back to the wiring, and wire the L&N to one side of the on/off switch, and the 2 white wires to the other side
Leave the hi/lo switch in if you don't want the hole
Plop the cord rewind in
fit the top cover
try it! You should easily see if the motor has blown when you get to it in the usual way!
« Reply #4 on: June 07, 2016, 10:39:26 PM »
thanks beko you really are the best  :thumbsup: :bow: :tiphat: :icon_nod:
« Reply #5 on: June 07, 2016, 10:50:35 PM »
Anytime mate!
I've done it alot, any 'dead' hi/lo henry/hetty gets checked to make sure it is just that before spending any money on it!
Offline aj2703
« Reply #6 on: August 24, 2018, 01:51:45 PM »
Don't suppose you could do a video..? I am just about to start refurbing and wouldn't mind knowing how to do that
