Author Topic: Anyone know any other 36.5mm Mini Turbo Tools to fit Sebo?  (Read 3223 times)
« on: June 18, 2016, 05:08:26 PM »
The Sebo mini turbo tools look like this:
But they are quite strong money.
Does any other brand anyone knows of also use 36.5mm tools? I'd like to find a cheaper alternative item that will fit Sebos that isn't naff. None of the after-market ones I found looked like they work.
Suggestions welcome.
Re: Anyone know any other 36.5mm Mini Turbo Tools to fit Sebo?
« Reply #1 on: June 18, 2016, 09:44:39 PM »
Is there an adapter to take it down to 32mm out there? If only someone could make one,  and then flog a nice set with a decent turbo brush...
Im not a fan of any mini turbine tool tbh, with the exception of the dyson tangle free job,  they always slow when pressed against anything to clean in my (limited) experience
« Reply #2 on: June 18, 2016, 11:15:55 PM »
Easily done, but it is a question of demand. Sebo isnt as big in the UK as they should be.
Why I am hoping for another solution.
« Reply #3 on: June 28, 2016, 04:49:54 PM »
Sussed it!  ;D
I found an adaptor that will make all first generation Dyson 32mm tools fit a Sebo. I've ordered some in, I'll update when they have arrived.
« Reply #4 on: June 30, 2016, 11:35:22 PM »
So here is the solution to make Dyson and/or 32mm tools fit Sebo vacuum cleaners: This adaptor.
Which we sell >>here<<.
Which allows tools with a 32mm hole as used on Dyson DC01-DC14 to fit your Sebo vacuum cleaner.
If your Dyson tools are the late type tool fitting like this:
Then you will also need this one.
Which you can find >>here<<
The mini turbine brush together with the adaptor, per my original query, you can now find >>here<<.
I like to solve problems.  :smokin:
« Reply #5 on: June 30, 2016, 11:49:35 PM »
Aha, the old Numatic double taper adapter! So many uses, well done! The one BIG problem I have with my AEG UltraCaptic is my Dyson soft dusting brush and 32-35mm adapter doesnt work, so I can't use it. Must get round to buying a 36mm square-32mm adapter for the UltraCaptic!
« Reply #6 on: July 01, 2016, 05:06:13 AM »
:o Looks like MV(sorry is it Claire or Olga?) will be replacing her trusty DC14!   :snivel:
And good job with the adaptors! I hate different dimensions even on the outside of tools, I once tried to fit a Vax wet spill pick up tool onto the end of a Dyson DC01 wand and it wouldn't fit, unless I used the hose with the adaptor or something like a DC07/14 wand.
The Sebo hose cuff looks nice! Great for car cleaning especially as it's small and simple.  :thumbsup:
« Reply #7 on: July 02, 2016, 07:53:52 PM »
Ohhh bloody hell, I have loads of extra Dyson tools and I just spent like 6 on a Sebo dusting brush that's crap, I have loads of those Numatic adapters and I've just tried it with the tools and my G1, works perfect... If only I'd have thought of this haha!!
« Reply #8 on: June 05, 2017, 03:33:00 AM »
Olga has already given up her DC14 for a Sebo X4 Pet in black.  :-X
