Dyson Models
Cylinder & Canister Dysons
DC39 Animal - how do you remove the hepa filter
2
Topic: DC39 Animal - how do you remove the hepa filter (Read 23401 times)
SpaceVacumm
June 28, 2016, 09:59:15 pm »
Reading the article from Dyson Tech (thanks and very helpful) I'm finding it very difficult to remove the Hepa filter and also separate the filter from the side ball.
As you can see from the description, I'm a noob and needs some help.
How do you detach the old Hepa filter without damaging the unit?
If anyone has pics, would really appreciate it.
Ta
Re: DC39 Animal - how do you remove the hepa filter
June 29, 2016, 12:18:20 pm »
From what I remember, the filter and motor housing are as one, then once out they seperate.
Look in the cylinder section at my stripdown thread, see if that sheds any light on it
SpaceVacumm
June 29, 2016, 12:58:30 pm »
Thanks.
Yes, I've seen and read up on all the threads on taking apart the animal but i just can't seem to dislodge the old filter from the housing. When back home, i'll send a pic to show all.
June 29, 2016, 02:11:16 pm »
If you mean the outer shell of the machine, have you pushed the 2 locking tabs in that sit under the side wheels on either side of the outer casing?
SpaceVacumm
June 29, 2016, 08:56:54 pm »
Please see pictures of the hepa filter im trying to remove without busting a gut.
Also how do you remove the hepa filter from the wheel reel that returns the long cable? (last picture)
MVacs
Administrator
June 29, 2016, 09:43:08 pm »
See if the description
here
helps any?
Sebo repairs in Manchester
Dyson repairs in Manchester
Sebo spares in London
SpaceVacumm
June 29, 2016, 10:04:29 pm »
Yes, already read this article :)
I'm trying to remove the Hepa filter as I've bought new one to replace the slightly dirty one.
I just seem to find what I need to do to remove the hepa filter from what it's attached too
June 30, 2016, 10:14:18 am »
I always thought it was glued, I certainly found no way of removing it from the plastic housing that sits on top. Do you have just the filter, or the filter attached to the housing that the cord rewind etc clips on to?
SpaceVacumm
June 30, 2016, 10:44:15 am »
I have the filter and housing - see below.
June 30, 2016, 10:44:30 am »
Like here, I could get the cord reel off the housing, but the plug would need to be snipped off and a new one wired on to get it out (or undo the cord from the reel but I REALLY would not recommend doing that), unless I missed something when taking it apart, but I don't think I did
Is how it looked from inside, and the filter ring seemed fixed to the top part. Does your filter have all this or is it just the white filter part? Where did you buy it from? Mvacs, do you have any in stock/can you see if the dyson replacement is just the filter, or the whole assembly?
A quick look on the Manchestervacs shop shows it comes with the whole housing, and that maybe there is a way to get the ring where the cord goes through off, as the replacement part has the part that receives it, you may have to carefully pry stuff with a screwdriver to see if it pops off.
So you need to have the whole lot out, take the motor housing out, remove the cord reel (twist the reel assembly and it unlocks from the center part IIRC), find a way of getting the cable guide off, and rebuild.
What was wrong with your old filter may I ask? Mine was pretty grubby but ultimately fine. Have you used it for DIY?
June 30, 2016, 10:48:50 am »
Ah it does!
Reading this
https://manchestervacs.co.uk/DysonForum/index.php/topic,1904.0.html
shows it laying on the side away from the filter housing
Stu, any hints on getting it off?
SpaceVacumm
Reply #11 on:
June 30, 2016, 10:58:07 am »
Yes, that's exactly what I'm trying to find out how to do. Take the motor and filter apart like shown in the picture.
Reply #12 on:
June 30, 2016, 11:00:14 am »
Well I wrote a step by step how to guide here
https://manchestervacs.co.uk/DysonForum/index.php/topic,2313.0.html
Which covers it when I get to that stage
and there is a 'motor change' tutorial here
https://manchestervacs.co.uk/DysonForum/index.php/topic,1218.0.html
which covers it as well
Good luck!
SpaceVacumm
Reply #13 on:
July 03, 2016, 09:08:01 pm »
Cracked it!..not the hoover.
Used a bit of f'ing and blinding and managed to snap off the old filter and casing. Luckily the new one comes with all in.
Popped in new filter and had fun with the winder of the cable as some parts internally decided to come off and become a right bar-steward to go back in again.
All in all, managed to get everything back in and hoover works... even ended up with one screw that I can't find out where it goes
Reply #14 on:
July 03, 2016, 11:49:39 pm »
Excellent! One screw will be fine, you won't miss it!
What was wrong with the old one out of interest? Carboned up or plaster dust?
2
Dyson Models
