Author Topic: The Dyson DC28c Cylinder  (Read 2550 times)
Offline dragoncurt
  • Dyson FTW !
« on: October 13, 2016, 02:57:03 PM »
Hi I came across a cheap Dyson DC28C on Ebay and it is not working but he does not know what the problem is. Could it be an easy fix.
Re: The Dyson DC28c Cylinder
« Reply #1 on: October 13, 2016, 05:24:13 PM »
Worst case scenario is a blown motor, check the fuse though (although they hardly ever blow on Dysons). Could be the cable where it enters the machine from all the tugging as well. If it's not working, *maybe* it's overheated and they assumed it died
« Reply #2 on: October 13, 2016, 05:27:06 PM »
Usually they sucked plaster dust/fire ash/shake and vac up it and it blows the motor.
Offline dragoncurt
  • Dyson FTW !
« Reply #3 on: October 13, 2016, 07:01:39 PM »
Oh okay then thanks for both or your ideas.
This is what he sent me when I asked about the DC28C
"It doesn't turn on (according to my wife, I haven't checked)"
I do not think he could even be bothered to check then, don't think he used it to clean up either. :)
Offline grahamwin
« Reply #4 on: August 21, 2019, 06:27:30 PM »
Hi Dyson fans re the Dyson DC28c is this ball cylinder machine similar to the Dyson DC39 ball cylinder, do they take the same tools, is the suction power approx the same, do the use the same filters and other parts ?
                                   Regards grahamwin
grahamwin
« Reply #5 on: August 21, 2019, 06:49:58 PM »
As far as I am aware they are one and the same machine.
Offline grahamwin
« Reply #6 on: September 04, 2019, 09:56:49 AM »
I see that some Dyson DC 28c and DC39 cleaners have motors rated at 750w and I think its the earlier ones had motors rated at 1300w, does this make any difference to performance or suction strength ?
                               grahamwin
grahamwin
Offline Halcyon
« Reply #7 on: September 04, 2019, 07:17:24 PM »
I had a pleasure to use this machine, and must say that it was a bit disappointing. Suction was good but it wasn't really moving easily on the carpet.
The worst was emptying though. The bin seems to be made of a really cheap quality plastic, you could basically easily bend it and you've got the littlest handle to hold it while opening.
I find Big Balls bin much better and much easier to empty, those machines seem to be much better in my opinion
Online bluebumble485
« Reply #8 on: September 04, 2019, 10:41:14 PM »
I sell loads of the dc28 and dc39 they are same inside and out ,motors are easy to change now I have my head around them ,the filter is harder if needs to be changed and dear
N95 Face Masks
