Ok, So using the Ametek rubbers and retaining ring would I be able to fit a Ametek motor to the Purple motor housing originally fitted with a YDK motor?
Quote from: Elgin on December 30, 2016, 03:44:30 amOk, So using the Ametek rubbers and retaining ring would I be able to fit a Ametek motor to the Purple motor housing originally fitted with a YDK motor?On a DC04, yes.
Unfortunately not, they are different for a reason and they are different sized.The YDK from a DC04 will fit the DC07, but a DC04 Ametek will not fit a DC07 (I tried once) it was just too small, the belt would keep slipping off the spindle because it just didn't fit right. The motor retainer is also there for a reason. It holds it in place. If the motor moves slightly, the spindle will be misaligned so the belt would keep slipping.You can use any DC07/14 motor in it TBH, even brand new cheapo ones from £13
Quote from: MVacs on December 30, 2016, 09:01:35 amQuote from: Elgin on December 30, 2016, 03:44:30 amOk, So using the Ametek rubbers and retaining ring would I be able to fit a Ametek motor to the Purple motor housing originally fitted with a YDK motor?On a DC04, yes.So using the retaining ring, and top and bottom rubbers i'd be able to fit an Ametek motor to my DC04 Absolute
I never knew a DC04 lime motor would fit a clutched YDK DC04, interesting I always thought they were smaller than the YDK by a bit
I sourced from Mancester Vacs, now I am not knocking Mancester Vacs in any way however I didnt realise that it would be second hand parts that was sent out and I do not have a problem with that but I couldnt help but think I have those parts in my spares pile as we all have one but I couldnt find anything so can anyone elighten me?
an adapter kit for it of which I sourced from Mancester Vacs, now I am not knocking Mancester Vacs in any way however I didnt realise that it would be second hand parts that was sent out and I do not have a problem with that but I couldnt help but think I have those parts in my spares pile as we all have one but I couldnt find anything so can anyone elighten me?
Now does anyone know what parts are used to make this YDK Motor fit into a DC04 Silver/Lime (non clutch)?
Quote from: ocddyson on January 08, 2017, 08:56:12 pmNow does anyone know what parts are used to make this YDK Motor fit into a DC04 Silver/Lime (non clutch)? They are the equivalent parts from the clutched model. Rare because not available any more new and a machine must die as a donor for each kit sold. We are discussing making the kit jointly with Q in order that more green DC04s can be saved. But demand may not make a production run worthwhile (hence the discussion).
