Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
News:
With photos. Find it
>here<
Click
>here<
Home
Help
Login
Register
Hoover Vacuum Cleaners
Hoover Turbomaster U5094 - Stripdown and Refurb
« previous
next »
Print
Pages:
1
2
Go Down
Author
Topic: Hoover Turbomaster U5094 - Stripdown and Refurb (Read 12214 times)
beko1987
Member
Country:
Gender:
Let's take it apart!
Re: Hoover Turbomaster U5094 - Stripdown and Refurb
Reply #15 on:
December 30, 2016, 11:56:45 pm »
Just re-assembled in reverse, with grease covering all contact points!
Bellows back on the motor
Onto the chassis now. Rear wheels on, drop of grease where applicable
Fir the slider part of the height adjustment, another drop of grease
and pop the front wheels on
Fit the clutch and clamp it down
Bumper fitted
Release pedal and spring fitted
Logged
beko1987
Member
Country:
Gender:
Reply #16 on:
December 31, 2016, 12:19:50 am »
Time for the suction box now, and this really could do with being sealed with silicone, but as you saw above, I need to have a nice new tube with a small directable hole, so another day...
Assembled
The lever moves so much better now it's clean and not binding on grit
Out comes the suction box again, and in goes the motor!
Back in goes the suction box
Clamped down
Onto the belt spring now, and here it is fitted, but it moves about very easily and needs some swear words to keep it in place
Fit the actuator pedal and spring to the black housing
Then remember that the back of the machine needs to go in first...
Remembering also to fit the two pivot points...
Logged
beko1987
Member
Country:
Gender:
Reply #17 on:
December 31, 2016, 12:26:30 am »
This shows (badly) how moving the machine upright moves the belt, the plastic pushes the spring to the side as the cleaner is raised, moving the spring. It also shows the wear on the release pedal, which is why the vac leans when upright. Possibly fixable by glueing a thin fillet of plastic to it, but how sturdy that would be long term, I don't know, so I left it alone
Make double sure the spring hasn't popped out...
I tried fitting the pedal assembly whole, but it kept moving the spring, so whip the pedal off, and just fit the housing. This holds the spring in place
Then fit the long spring
Then the lilac pedal. Check the operation, the pedal should 'lock' when pushed then unlock when pushed again and pop back.Fit the orange piece and 2 long screws
Then swear lots, as you realize the spinal cord needs to go through, so have the lot off, and run the cable through the body... (good practice though)
Done! (much easier the 3rd time). Fit the pivot clamps, with a drop of grease to ensure smooth operation
The bellows went through the washing machine too and didn't come too clean, but too late now. Hold them in the slot on the housing and fit the trunnion cover
Logged
beko1987
Member
Country:
Gender:
Reply #18 on:
December 31, 2016, 12:31:30 am »
Onto the hood now. First to go back in is the divider bit. The foam was starting to peel away, but was fine overall
The hood cleaned up well, and shows the lilac slate off well, sadly the machine is quite faded externally
Fit the slider to the lens with a drop of grease on the contact points
The adjuster knob needs to be laid onto the hood next, and lined up with the slider plate as you fit the lens
Done
Next was light, and a few years ago, I was given an LED kit to fit turbopowers and turbomasters (and lots of other bits), so thought I would fit it to this!
It has a big sticky pad on the back, but I found it slotted very nicely into here and held very securely
the lead is long enough to plug in and unplug to get the hood off
And with that, the hood can be screwed down.
Logged
beko1987
Member
Country:
Gender:
Reply #19 on:
December 31, 2016, 12:35:57 am »
The hood has shine back in! Not quite as good as it could be, I'll re-visit it one day
Activator next, and 2 more new bearings were procured
and fitted
That all back together, it was time to belt it up
I've had this pack of belts for ruddy years! In the hope that one day, I would get a TurboMaster. This day had come, and I was very happy to be fitting them
The old belts weren't too bad really, but they were changed anyway
And what a complete bastard it was to fit them! very very fiddly
But in the end mild violence won the day and the activator was fitted with fresh new belts
Logged
beko1987
Member
Country:
Gender:
Reply #20 on:
December 31, 2016, 12:40:15 am »
Lovely
The baseplate went back on
And now we move back up the machine, with the bottom part fully done
The wires and conduit were fitted up the bag housing
The suction bleed valve tube clipped onto the bag fill tube and fitted
Some nice new tape had the 2 parts of the bag fill tube fitted together again
I fitted the fill tube, and the top holder part, and here you can see the back of it that supports the wiring, so I wired it all back up again
and fitted the cover and top cord hook
The bag door catch fits back onto the inner housing that goes under the top cover plate
Logged
beko1987
Member
Country:
Gender:
Reply #21 on:
December 31, 2016, 12:49:45 am »
The suction vacuum valve is fitted and wired back up after a squirt with some contact cleaner
The LED was fitted back into the cover plate, the cover palte popped over the inner plate, more wires pushed together and the bag door button reassembled...
and it was fitted to the machine. A nice H4 bag was found, and a bag slide
The air freshener housing and slider fitted to the bag door, and the bag door fitted to the machine
The very clean hose was found and re-united with it's vacuum
The cleaner tools refitted
and the handle reassembled and fitted!
And the end result...
A beautiful machine!
Bit of a lean on her though
but the total system Turbopowers were always terrible for this, all the extra weight on the top doesn't help. I have 2 TP1 total systems in the loft with smashed trunnions that needs reconstructive surgery next year! Works OK if I give it a hand though
But was all this work worth it? The proof is in the after video!
//www.youtube.com/watch?v=1zgi4aqsWy8
It's amazing now! All that did not work before now works a treat, it's issue was just filth! Might try and get a new activator for it sometime though.
But for now, thank's for reading, and happy new tomorrow!
Logged
dysondc16
Member
Country:
Gender:
Reply #22 on:
December 31, 2016, 05:04:18 am »
That was really interesting seeing how the belt system on this works. It's strangely reminiscent of the self propelled hoover windtunnels we got (and still get) over here.
Looks like it came out really well!
Logged
Print
Pages:
1
2
Go Up
« previous
next »
