Author Topic: Dc22 with dc08 floor tool possible  (Read 3872 times)
Offline Mike.heath
Re: Dc22 with dc08 floor tool possible
« Reply #15 on: May 09, 2017, 05:33:40 PM »
I'll have a go at your suggestion looks like the only way it will work. The reducers/adaptors are ones I had with my handheld dyson (bought it as a refurbished set) the reducer dosent go inside or over the turbine adaptor unfortunately
Offline Mike.heath
« Reply #16 on: May 09, 2017, 05:34:10 PM »
Thank you for your help so far
Offline Elgin
« Reply #17 on: May 11, 2017, 06:33:52 PM »
Elgin is wrong.
I am not aware there is a reliable adaptor to do what you want. But there may be a work around.
The DC08 head you have, measure across the inside of the tube hole. What does it measure in mm?
Also a photo of the tool ends of old and new would help.
You are correct this is a minefield. Especially with DC08 and DC19 heads. Why we sell >these<.
The other problem you have is any head that is bigger than your original will struggle to spin very fast as the DC22 is a smaller machine than normal with less suction than a full size cylinder.
I dont really have much idea about these adapters
