Author Topic: Dyson DC40 Mk1 (Pre EU) - Stripdown and Refurbishment  (Read 33768 times)
Re: Dyson DC40 Mk1 (Pre EU) - Stripdown and Refurbishment
« Reply #15 on: July 21, 2017, 02:21:48 AM »
Up top now, and the very clean filter can be removed
And split
The carry handle unclips from the back to come off completely
The red release button and spring pop out of the carry handle
The handle is a bouncy one, the two halves given their spring by a, well, spring!
The clue vanity cap to mark the filter pops out
and it's seal can be removed
The bouncy handle separates
And we can get to the main cyclone!
« Reply #16 on: July 21, 2017, 02:26:33 AM »
The top bin seal lifts off
And by popping the 4 tabs one can split the cyclone from the shroud
and remove the shroud and outer cyclones
OMG Plasterdust! I'm so happy to see this!  :thumbsup: Dysons love plaster dust, I'm glad it's had some
Awful image but the shroud can be removed now, although it's VERY flexible when off, can barely hold it's own shape...
To the top half now, and the cyclone tip seal pops off the cone tips
And buried deep under all the shyte are some screws
Which when removed do this:
The very tip of the inner part of the cyclone has a rubber seal that mates to the suction channel under the bin
« Reply #17 on: July 21, 2017, 02:28:33 AM »
And finally the foam gasket can be removed
and IT. IS. STRIPPED!
Everything was washed and dried
and polished, and ready for re-assembly
Which will follow on another day, because I'm tired, and need to go to bed, it's a work night!
Stay tuned for the 96 reassembly pictures!
Offline ollivacguy
« Reply #18 on: July 21, 2017, 02:30:00 AM »
That all looks a bit more complicated than a DC04 or something of similar Chassis/ design.
« Reply #19 on: July 21, 2017, 02:34:05 AM »
Ooooh yes! It makes a dc24 seem very very simple!
« Reply #20 on: July 21, 2017, 11:04:41 PM »
Ugh DC40 Mk1...
I'm waiting for the day you get a DC41- much easier to strip, assemble, better performance, etc! I just love them haha
Brilliant stripdown so far btw (as usual ;) )
« Reply #21 on: July 21, 2017, 11:09:04 PM »
Ugh DC40 Mk1...
Thanks! Sure I'll get a 41 one day!
Even though I did this refurb blind and with nothing to loose if it all went wrong, the pictures will hopefully help people pinpoint issues with their dc40s
Offline dysondc16
« Reply #22 on: July 22, 2017, 04:41:52 AM »
Thanks a bunch beko for the stellar pics on this thread. I'm sure I will need this in the future  :tiphat:
Not a big fan of the dc40 either, I only keep mine because it isn't bad on hard floors.
« Reply #23 on: July 23, 2017, 09:34:37 PM »
Right, let's carry this on a bit now I'm not falling asleep at the keyboard!
Everything was um, washed, polished, and um, ah yes  :thumbsup:
Virtual hi-five for the first person to type up the complete part list from that picture!
*sigh* I suppose it's time to put it together again! Cyclone first
Cyclone gasket fitted
Fuzzy end tip seal on
And the top part can be popped together and screwed down! I had to clean the heads of these screws out with a few bristles of a stiff brush, then they were much easier to do up!
The lower rubber gasket can be clipped onto all the tips now
The shroud can be clipped onto the lower cone
I got the red middle part of the bin release rod and spring together
« Reply #24 on: July 23, 2017, 09:39:29 PM »
Then battled to get the removal button spring back on, then the two cyclone halves clipped together without trapping the spring, the spring not being positioned right, the spring flying across the room or sometimes multiples of the above  >:(
Once that was done, the red middle part and spring had to go in. This is as much of a sod as a DC24 one is, and since I haven't found a foolproof way of doing it yet, after much swearing it sat correctly (it needs to be held out against the stopper, so it slides over the bin and not into it)
Then... buggar, I found this seal which had dropped out whilst washing
And yes, all the above had to be undone to fit the seal, which is actually a sod, I don't recommend removing this if you can help it
Red part sitting properly against the backing bit
That done, I could clip the cyclone handle together
Not forgetting it's spring
The filter cover seal gets re-fitted
And snapped into place under the handle
« Reply #25 on: July 23, 2017, 09:43:42 PM »
The top part of the whole bin flap rod sits over a spring which sits in the handle
The red part itself clips in, making sure all the various runners are aligned
Filter now, and the top seal gets fitted
Then the bracing cage
Then fitted
And the lid shut
Onto the other end of the assembly now, the bottom bin flap
Rubbered up for safety
Then fitted to the bin, and the red rod slid and clicked into place
« Reply #26 on: July 23, 2017, 09:48:55 PM »
And the cyclone assembly is done!
Brushroll housing now!
The cog and bearings were fitted to the housing
This was clipped to the brushroll motor and the belt fitted to stop it all falling apart
The middle brace and spring were added, then the whole lot screwed together quickly before the sping decided to go for a jog
The motor assembly was fed into the mounting plate, and the brushroll cogs fitted
and the middle wheel dropped into place
Housing now, and I snapped the base plate on
Now I knew how much force the wiring loom needed it was fitted very quickly
And the plug and wire cover refitted
« Reply #27 on: July 23, 2017, 09:55:21 PM »
The motor assembly was laid into place
And the screws on the top fitted
The motor cover and segmenting barrier were snapped on
And then screwed down, along with the wiring cover
Brushroll end caps next, and this took 2 attempts, because as I mentioned during disassembly, their handed...
See  :underchair:
A quick swap round had them screwed down nicely
Then the base plate (which by the way was full of fluff around the inside of the rubber membrane. It all started pouring out whilst I washed it, it moved about ALOT better after this, if your DC40/41/any of the modern dysons with a base plate like this start not working very well, check this!) ahem, was fitted
And the brushroll housing is finished!
« Reply #28 on: July 23, 2017, 10:02:14 PM »
Onto the motor now, and this part was blurry in real life, that's certainly not my camera doing that...
Then this latch was fitted
And the cover quickly bolted down
Inside, and the motor seal is fitted
The carbon brush removed from the motor again
which was fitted, carbon brush replaced, inner fancase seal fitted and the top screwed down!
Changeover valve now, and I put the rubber seal on
Fitted the spring to one side of the securing cage
And slid it into place on the internal hose
« Reply #29 on: July 23, 2017, 10:12:57 PM »
The other side, which actually holds it to the machine slid in place
And the whole thing slid into the chassis, screwed up and the springs fitted. I put a drop of glue on the small hole in the hose from the wooden skewer to fix that!
Next thing to do was to thread the spinal cord into place on the upper chassis (which turned out to be a mistake, but I think still the correct process, just pay more attention than I did to the markings from when the cable was fitted before to line it all up...)
The spinal cable was screwed into place on the lower chassis
Blockage trapdoor fitted
Underneath now, and the wheel assembly is fitted
The spring replaced
The brushroll switch cam fitted
And the brushroll switch itself
