Author Topic: Inherited Hoover  (Read 840 times)
Offline baron_matt
Inherited Hoover
« on: July 31, 2017, 05:50:06 PM »
Hi
I've inherited a Hoover model number U4002 and I'm trying to bring it back to life. Some time ago when still in use the bag bellows split and the bellows ring broke I suspect when my Grandfather tried to change the bellows so it was pushed to the back of the cupboard under the stairs and forgotten about.
Sadly he passed away now and in sorting out his effects I found the hoover. I've managed to track down a bellows and a replacement bellows ring, however I notice that its standing a bit lopsided. Further investigation shows that there is a lot of play between the rear wheel axle and this metal bracket that is screwed onto the underneath. The metal bracket holds the wheel axle tight against the chassis casting...well is supposed to, but on this machine the bracket has worn away. Does anyone on here know if anyone has one of these brackets or if there is something missing from causing the wonky stance?  Pic attached of the underside. Many thanks Matt
Re: Inherited Hoover
« Reply #1 on: July 31, 2017, 11:55:33 PM »
Hi Matt!
Nice vac, sorry to hear about the circumstances in which you acquired it though...
It's been many years since I've had a Ranger, have you fully pinpointed the wobble down to that bracket? The axle itself shouldn't move I don't think, so maybe try packing it out with a few wraps of insulation tape around where the axle passes through the bracket? From what I can see though it doesn't look that worn, certainly not enough to make it lop sided.. When upright, can you physically push any of the parts around?
Offline baron_matt
« Reply #2 on: August 01, 2017, 12:28:03 AM »
Hi Beko
Thanks for the reply. Well it is a bit strange but I have no experience of these big fellas as I run a Junior at home so I was expecting it to be the same. On this machine the height control is on one side so essentially the weight of the machine pushes down on the rear axle. Common sense would have had that axle passing through a nylon bush or something but it appears on these that the steel bracket (does it have a name?) is all that holds the axle hard against the chassis. The Axle also seems to move from side to side as there is nothing to secure it into a specific place. There is a slot cast into the chassis and there appears to be a notch in the axle but no evidence of anything. Should there be a clip or something? There is a washer but this looks wrong and doesn't do much. Hopefully this pic shows how lopsided this axle is.
« Reply #3 on: August 01, 2017, 01:49:50 AM »
Matt, I have pushed the link to your topic here out on our Facebook and Twitter as well as there are lots of the vintage vac guys read these channels.
Beko above is one of our vintage Hoover gurus, but other opinions are valuable too.
Stick around, you'll get some more good replies I hope.  :icon_nod:
« Reply #4 on: August 01, 2017, 02:28:26 AM »
An empty notch mat imply a missing circlip. I've got a Hoover Senior 652a in bits atm, and that has circlips in all those grooves you speak of.
Try wrapping a bit of wire around the groove to simulate a circlip and see if that improves it. Otherwise now Stu has shared it someone more iknowledgeable with the older machines than myself should pipe up!
Something does look amiss though, it shouldn't be that lopsided
Offline baron_matt
« Reply #5 on: August 01, 2017, 10:41:48 AM »
Thanks guys
Online Madrat
« Reply #6 on: August 01, 2017, 05:11:17 PM »
I think the bracket is the guide for the tool adaptor. Never even been close to one of these so not much help.  :grinn:
Offline baron_matt
« Reply #7 on: August 04, 2017, 12:17:53 AM »
Oh dear
further looking at this U4002 and the fan is shot. It has a cast metal fan and at least 3 blades missing and the pulley is quite worn too. Any ideas on these? I expect these are not parts that you can get?
« Reply #8 on: August 04, 2017, 12:23:49 AM »
You'll still get pattern fans and possibly, Stuart, can you check Q?
« Reply #9 on: August 04, 2017, 11:52:11 AM »
Is it the same as a 1334?
I'm not hot on the old Hoover stuff, and there are many fans.
« Reply #10 on: August 04, 2017, 11:54:45 AM »
No, their bigger. I've got a q book at home I'll have a look.
And there's lots of Hoover fans, many on your forum. Don't be so silly!
Offline baron_matt
« Reply #11 on: August 04, 2017, 02:32:15 PM »
Thanks everyone so far for all your help on this. :tiphat:
« Reply #12 on: August 04, 2017, 02:55:07 PM »
Turns out myself and Baron_Matt live very close to each other. This should make diagnosis much easier! Pop round one weekend Matt and we'll have a look, and you can have a play with the toys. Might have my Concept One working by then, still got a Kirby G4 for a few days too as the owner is on holiday!
Online Madrat
« Reply #13 on: August 04, 2017, 03:54:07 PM »
Think you can get them on ebay.
None on there at the moment though.
« Reply #14 on: August 04, 2017, 04:56:24 PM »
Don't be a plonker. I mean when I put in Q fan for Hoover vac, it shows me 6 pages of the buggers. By not hot I mean not up to speed with identifying parts. I've forgotten them all since I learned them in the 80s.  :chuckle:
The Dyson Medic Blog
