Author Topic: Gtech Air Ram Mk1 - Brushroll Cog Replacement How to Guide  (Read 15116 times)
Offline Angiew144
Gtech Air Ram Mk1 - switching itself off following cog replacement
« Reply #15 on: April 04, 2018, 08:48:09 PM »
Hi, I stripped my G tech down and replaced the cog. Started first time and the horrible noise has gone, but it’s turning itself off after a few seconds. It will switch back on but does the same thing again and again. Battery is fully charged. Don’t know if there was anorivlen before I replaced the cog because I only just bought it second hand. Any ideas? Is it likely I've trapped a wire or something when putting it back together? Or does it sound like a battery issue?
Re: Gtech Air Ram Mk1 - Brushroll Cog Replacement How to Guide
« Reply #16 on: April 04, 2018, 08:52:56 PM »
Check the brushrolls are back correctly, it sounds like it's encountering resistance, and cutting off to be safe. Remove the brushrolls and see if it runs any better. Is it fairly easy to spin by hand? There will be motor resistance, but it should turn fairly easily.
Otherwise it could be the battery, but short of the expense of buying another just to see there isn't much you can do there.
Offline Angiew144
« Reply #17 on: April 04, 2018, 09:13:43 PM »
Yes the brush rollers are moving easily by hand. I’ll borrow my friend’s Gtech and try her battery. Jeeze, if it’s the battery I’ve been well and truly had off with this!
« Reply #18 on: April 04, 2018, 09:33:25 PM »
Yep, always a risk! That's why we don't like them very much, very fiddly when they go wrong, and parts are still quite expensive for them!
Good luck though, keep us posted!
Offline Angiew144
« Reply #19 on: April 04, 2018, 09:36:52 PM »
Battery works fine in friend’s machine! And when I put her battery into this machine, the problem still occurs. It’s intermittent though, sometimes it works fine. Wondering if it’s a switch problem? Or something to do with the way I’ve put it back together!
« Reply #20 on: April 04, 2018, 10:10:30 PM »
If your feeling brave and bribe your friend, drop your motor into her chassis... It won't need to be screwed in, literally just unscrew both and drop the whole motor unit into her known good machine
Offline allyboy
« Reply #21 on: November 20, 2018, 11:41:30 PM »
Has anyone seen the drive cog look this worn?
https://ibb.co/ciJgXA
https://ibb.co/c80ZkV
don't see anyone selling these and don't see how this can work normally unless a tight fit etc.
