Author Topic: Dyson DC41 Mk2 (Erp) - Stripdown and Refurb!  (Read 21311 times)
Re: Dyson DC41 Mk2 (Erp) - Stripdown and Refurb!
« Reply #30 on: November 04, 2017, 01:38:08 AM »
Next, run all the wires where they need to go under the airflow duct
Then, fit the first half of the airflow duct, running the wires through their holes
Pop the PCB in, screw it down and populate the wires
Fit the seal to the cyclone locating part, then fit the top half of the airflow duct and screw it down
Grab the part I kept calling the wheel housing earlier, which is actually probably maybe the yolk assembly, and fit the 2 rollers
Fit the white cog
Next, fit the stabilizer lock bar to the internal hose bracket
Screw this to the other bit
« Reply #31 on: November 04, 2017, 01:43:10 AM »
Clip the washers and cradle to the wheel axle
Then drop the whole lot onto the machine
And do up all the screws, manipulating it about as it need to be manipulated
Pull the internal hose out and secure it in place at the top
Fit the post motor filter back plate and hide all those nasty screws
Next, find the brushroll plug cover and feed the wires under the plastic part
Wire it all back up
And fit it into place
« Reply #32 on: November 04, 2017, 01:47:22 AM »
With that, you can recline the machine if it's not already, and slide the top cover on
Then, fit a wheel!
Pop the post motor filter back on
Then fit the other wheel
Up top now, and fit the wiring to where it needs to go, plugging it in here and there
Pop the switch covers together
Then fit the switch cover to the chassis, checking switch operation once screwed together
Tools back on!
« Reply #33 on: November 04, 2017, 01:52:57 AM »
Wand handle next
Popped that onto the cleaner
Hose now!
Inner red locking ring and spring fitted now
White cover clipped on (I think this stops the red part pinging out and it all jamming up if the hose is pulled on the wand)
Push the outer rubber collar onto the inner black collar, lining up the tabs
Then clip the end part onto all of that
« Reply #34 on: November 04, 2017, 01:58:26 AM »
Hose is a bit cleaner for a spin through the washing machine
Next, fit the stupid bottom cord hook, then wipe the smile off it's smug stupid falling out face by fitting the hose, trapping it forever
Blimey, 1 SCREW LEFT  :king:
Which sits under all this
Clunk, Click
and it's done!
So there we have it, the first ever Dyson DC41 Mk2 stripdown thread probably anywhere, and since Dyson do not release the service manuals, probably the only place you will find the info!
I hope this helps people who want to fix or refurbish their own machines, collectors have a good ogle at the inside of one, and people in the trade who will do what I will do, and in the future follow this thread with their own basket case model sat on the bench!
As always, thanks for reading! I'm off to bed.
« Reply #35 on: November 04, 2017, 01:55:31 PM »
Epic.  :bow:
Online ryevac
« Reply #36 on: November 04, 2017, 04:03:32 PM »
Thanks for taking the time and effort on this one.
Offline premierdysonrepairs
« Reply #37 on: December 16, 2017, 02:52:31 PM »
Much appreciated, as I have on sitting requiring a main motor. :thumbsup:
« Reply #38 on: December 16, 2017, 06:29:42 PM »
Don't know what it is but even with this fantastic thread noting interests me at all about these newer dysons, I just think there to over complicated for no apparent reason.
Online Halcyon
« Reply #39 on: September 02, 2019, 05:32:56 PM »
I'm literally speechless. First of all I wouldn't even know how to take it apart but then to put it all together, man ..
I would probably sit and cry if I had to put it all together  :underchair:
It's unbelievable, I'm so impressed.  :bow: :bow: :bow: :thumbsup:
