Dyson Models
Dyson DC41 Mk2 (Erp) - Stripdown and Refurb!
Pages:
2
3
Topic: Dyson DC41 Mk2 (Erp) - Stripdown and Refurb! (Read 54084 times)
Re: Dyson DC41 Mk2 (Erp) - Stripdown and Refurb!
Reply #15 on:
November 03, 2017, 10:04:04 pm »
The cogs and bearings pull out easily
The belt guide unscrews, and has a little spring underneath
The motor mount is not too clever either
Unscrews for washing
Motor ID
Onto the cyclone now!
Take the bin off
Take the bottom flap off
Reply #16 on:
November 03, 2017, 10:08:09 pm »
The bin release rod can be unclipped easily
And removed which is great as behind it is really gritty
These manky seals pull out of the bottom flap
The pre motor filter is actually quite clean
The rubber seal pulls off
The top ring unclips
Inside shows it's not quite as spotless as it could be
I spy plasterdust...
Reply #17 on:
November 03, 2017, 10:13:55 pm »
With a firm lever in the right place, the bin flap release button pops out of the handle
The spring pulls out from underneath the red button
The cyclone handle unclips from the cyclone top, and the blue filter top unclips from that
With another rubber seal around that
*Don't do this, as it's an utter sod to reassemble* The 2 parts of the handle seperate, and release their little spring
Moving down a bit, the bin to cyclone seal pulls off
Next, release all the clips around the edge in turn
Then on the last one there will be a CRACK as the assembly splits when the final clip lets go and covers you in dust...
Reply #18 on:
November 03, 2017, 10:20:08 pm »
The locking tab for the bin has a little spring behind it, and although the tab won't come off easily, I didnt want to loose the spring so off it came
With a small flatblade screwdriver, gently prise the shroud off the cyclone assembly. Be careful as it's properly flimsy when not attacked
I found this a bit odd, the middle release rod spring could exit through a hole at the bottom of it's mounting bracket, so out it came on its own
The inner cone top seal comes off
Next, the foam gasket that runs around the little inner cyclones comes off with levering required all around for a bit
More gentle levering required and this white plastic frame pops off. It's gripped on each cone so is a little time consuming, and you cant lever too hard or you'll break through it
Being stuck on with plaster dust probably didnt help though
Buried under all that lot, and all this lot are the screws that hold the top on
With all those removed, the top falls apart
Reply #19 on:
November 03, 2017, 10:25:10 pm »
Revealing more white death
The middle rod is removed now
The two halves of the inner assembly are sealed with a foam gasket which pulls carefully off so it isnt torn. No sign of wear though, but it's hidden away unlike the foam gasket on a DC24/25/33
Either way, THAT'S IT!
Everything was soaked to dissolve the grime, then washed, polished, dried and laid out!
And now, we get to put it all back together YEY!
Starting with the foam gasket
Which only goes on a certain way, you have to line the notches tabs and screwholes up
I went to refit the middle rod and spring
Reply #20 on:
November 03, 2017, 10:40:37 pm »
But the spring came out the bottom, so I worried about that later
I couldn't really photo the steps next, but basically take the now clean top cover, insert the middle part into the inner cone and screw it all back together!
Pop the plastic cone frame on
And it's foam gasket, paying attention to the locating tab on it too
Inner cone tip seal on
Shroud now!
Which thanks to its complete lack of any rigidity when not on the machine is a complete pain, but eventually it clips on
Bin securing latch spring on
Reply #21 on:
November 03, 2017, 10:46:15 pm »
Connecting the 2 parts of the cyclone together is simple, except you need a tiny screwdriver to tease the little latch spring onto it's resting place before fully clipping the 2 parts together. Do-able with care though.
ALSO, we need to sort the middle latch spring. Before clipping the 2 parts together, insert the spring so it sits like this (it should just sit like this anyway as it's not under tension
Once the two parts are clipped together, there's just enough space to push the tab round and it'll drop into the notch in the casing, and be tensioned!
Top bin seal on
We need to put the handle together now...
Looking at the time stamp of these two pictures it took 17 minutes to do this! The parts need to twist slightly, but there's no room to twist. Slight anger did the trick in the end...
Pop the seal back onto the filter cover
And clip that into the handle
Put the outer spring in
Reply #22 on:
November 03, 2017, 10:50:12 pm »
Then push the release button in and check it operates fine
Fit the handle to the cyclone and check the release mechanism still operates as it should, pushes the middle part down, springs back etc
Pre filter next
Pop the top cap onto the main frame, there's a matching thing to line up on here too
Pop the seal onto that and drop it into the machine
Clip the top down, then grab your flap
This was a bit fiddly, but push the rubber seals back into place on the bottom flap
Snap the bin release rod in
And fit the flap to the bin using the under arm bear hug technique to squeeze the bin slightly and widen the locating tabs
Reply #23 on:
November 03, 2017, 10:55:10 pm »
And fit the bin to the cyclone
And that's done! Check the release mechanism works properly again etc and one job is finished!
So we dive nose first into the next bit... Fit the cog mech holding plate to the brushroll motor
Pop the spring in the belt tensioner locating block
Then drop the plastic peg on and do the screw up
Next, grab the main brushroll cog
The bearing felt a little dry, so pop the black cover off the bearing with a tiny jewelers driver
And pop a smear of grease in there
Then pop the cap back on! No need to do both sides, the grease will work its way through in use
Drop the cog into the housing, then fit the belt
Reply #24 on:
November 03, 2017, 11:02:57 pm »
Fit the centre wheel and axle to the housing
Pop the other side of the housing on
Fit the rubber jacket to the top of the brushroll motor
SHINEY
First thing to fit is the wiring loom. Observe the correct orientation (guess what I had to do...)
The motor retaining plate looks a little better now
Fit the motor
Drop the motor assembly into the head and check it's located properly
Screw that down, then run the wires
Reply #25 on:
November 03, 2017, 11:08:57 pm »
Run the wires around in their channel
And plug them in! The plugs are different sizes so no fear of getting it wrong
Pop the brushroll cogs on and screw them up
Pop the little wiring loom cover onto the connecting neck
Then fit the deflector plate and screw it down
Grease the brushroll bearing end caps the same way as we did the brushroll cog
Then screw them down
On one side, the bearing stayed on the brushroll, and through fear of snapping the bit it pushes on to, I left it there. It was showing signs of ill health
Reply #26 on:
November 03, 2017, 11:15:04 pm »
The brushroll and cog have a bit that need to line up
Once you work that out the brushrolls slide on easily, and the end caps can be screwed down
Drop the front bumper onto the head
Next, pop the slider frame onto the sealing strip, with a lick of grease to try and make it easier to move, as I always find these things incredibly stiff to move from max to normal
What follows was me finding out how fiddle it all is. The black frame sits behind these parts, wheras the sealing strip sits infront
But you can't just drop the lot in, as it's recessed, so the black slider sits inside the frame almost...
Eventually, I got it in, mainly by putting the black slider in, then one by one pulling each locating tab out and clipping the sealing strip on. Eventually it all dropped into place and just worked! Red slider got clipped on quick sharp
Then the two halves were screwed together
And with the baseplate latched shut, number 2 can be ticked off the list
Reply #27 on:
November 03, 2017, 11:24:34 pm »
Don't fall asleep at the back there, final stage now!
Drop the locating bar and big spring into the motor housing
Then before it all pings out and takes your eye out screw the cover on
Drop the motor rubber into the casing
Time to start assembling the changeover valve
To cure the sticky release valve this seems to have (the main reason it was so cheap I think), a smear of grease was deployed
Slide this part in, and screw it from the other side
Little teeny tiny damper now
Reply #28 on:
November 03, 2017, 11:29:15 pm »
Screw the damper to it's frame
More magic moving fluid
And it slides in from the other side and screws up
Next, grab the top half of the spine and throw the cable through it, using the existing pressure marks to line it up
Line it up and check the cable falls where it's supposed to (I didn't check this on the DC40 from that thread and it was a right apin to sort
Once happy, screw it down
I fitted the bottom cord hook here, but TBH don't bother and do it with the hose as it falls out alot...
Pop the air path window on
And feed the motor wire loom into the motor housing and make sure the seal fits snugly
Reply #29 on:
November 03, 2017, 11:33:14 pm »
Grab the brushroll loom and run the wires behind this plastic part
Fit the release valve into the lower part of the airflow duct
Wire the motor up and drop it into the bottom mount we dropped in earlier
Pop the fancase seal on and then fit the cover and screw it down
This cord clamp needs fitting
Pop the wheel assembly on
Refit the tension spring
Next, fit the cam that controls the brushroll switch
Then the switch, and run the wires to it and connect them up
Pages:
2
3
Dyson Models
