Author Topic: Hoover Senior U4058 Co-Op Exclusive - Stripdown and Refurb - A Museum Piece!  (Read 3833 times)
The top half was screwed up
Cooling fan screwed on
And a drop of lubrication was added to the top sleeve bearing
Which was then fitted
Underneath now
The spacer washers, fan and spindle were fitted
Then the outer seal
Then the sheild
The whole lot was then dropped onto the chassis
The various wirings were wired up/pushed towards where they needed to go
Now, it was time for some improvement, so I snipped the spinal cable from my spares DC07 and bought it in, then precision measured* the precise length I needed and cut that to size
Using the inner cores from that, and some crimps procured especially for this job as I didn't have any, I replaced the supressor with wires, keeping as much of the original cables as possible incase Stuart fancies re-instating it one day and playing russian routlette
It vaguely follows the original path
I even put the now bypassed supressor back in, lest it should add to its value one day
Improvements over, time to pop the front wheels back in
Then, time for the handle bail, bag holder, metal bar and a hammer, and a nice layer of grease everywhere
Handle release pedal greased up and fitted (the rollers it rides on were lubricated too)
Then the pivot brackets fitted as it holds it all down
Wire holder circlipped into place next
Then the height pedal
The one wheel was fitted to the rear axle
Then it was all slid into place and completed
Tool plate now
The spring and bar were fitted to the plastic firewall, with a squirt of lithium at all possible times
Then it was screwed down
The mains switch was fitted
Spring for the rear wheels was fitted
One of the metal screw threads decided to fall off at this stage, so here's what it looks like!
A slight tweak with some pliers had it gripped on once more
The back plate for the 2 speed switch was fitted now
Then  the switch itself
Then both covers. I also re-positioned and re-glued the ratings plate so it wasn't hanging off so much
It now stands up correctly
Time to fit the baseplate seal to the baseplate
Drop of glue here and there will hold it enough, it'll be clamped between plate and machine for ever more anyway
I then had another brilliant idea, and grabbed the 900 miles of foam strip left over from the Hoover Sensotronic, and cut a little piece off
To replace what I imagine was a similar sealing piece here for the plastic flap
Whilst that stuck, I grabbed the cable
As I'd noticed, whilst cleaning, that the neutral inner core was exposed, so had to chop the lovely original crimps off
I then, after ruining the whole machine, built the wiring block back up
Done!
I then got my box of cool senior stuff Dilys sent me ages ago fro my Hoover Senior 652C, and found a belt
Even from a genuine packet, it's a pattern part belt!
Still, does the job
Baseplate on
I also had a spare lamp
But had to stop, as I'm not qualified in electronics... (Microsoft VBA and ISTQB Foundation qualified, but that's no help here)
However, I stuck 2 fingers up to the man, and fitted the bulb
With that done, the upper hood can go on
And we can start to finish off. The vintage cardboard was still needed, so back on it goes!
And with some precise tweaking, got the handle bolt to hold the handle rock solid
A slight tangent here to the mains plug. And whilst doing all this, I realised that the plug was possibly original... So polished the pins up with the rest of the metalwork
re-wired more tidily than it was before
Much better!
And with that done, and the top handle attached, it's finished!
But did it work?
Yep!
So it was time for a few layers of wax
So are we done now? Well no! You see,  Mr Stuart has said to me before that he would love a toolkit with one of these old wrecks one day. And I just so happened to know someone selling some. So, in early september, I unboxed all of this!
Not all of it was mine, 1 senior toolkit and a dustette was for someone else who happens to live very near me, so I saved him some postage, but I ended up with 3 toolkits, two for my own machines, and one for Mr Stuart!
I gave him the boxed one, as it's probably easier for him to store
it had a floor and wall brush
A Crevice tool
Dusting Brush
2 wands
and a hose and adapter
Couldn't quite let it go out the door like that though, so I spent many hours cleaning the hose up
Until eventually I had a toolkit fit for display
With some tape, the box stayed together too
And boy, do they complete the machine!
So there we go, NOW we are finished! Time for an after video
Hopefully Stu can post some pictures up of it in it's new home, I think some might be up in the museum thread actually.
Still, onto the next terrible vacuum he has sent me for a wipe over!
Thanks for reading, good night!
Amazing commitment, and patience... great job
Online Sebo Dan
Fantastic restoration   ;D
Dan
Sebo Automatic X4 Extra Eco (Blue & Yellow - 1100 Watts), Sebo Ensign SM1 (Grey Black & Orange - 1300 Watts), Sebo Automatic X1.1 Eco (Arctic White & Grey Black- 1100 Watts), Sebo Automatic XP10 (Light Grey & Grey Black - 890 Watts), Numatic Hetty HET 160 (Pink & Black - 620 Watts) & Numatic Henry HVR 200 (Yellow & Black - 620 Watts)
Its an epic job, I had a go around the floor with it and it runs like a dream!  :bow:
Many have admired it in the corner of our shop where it now resides.  :icon_nod:
Thanks. It helped that it was a good one to start with! It (and the 652 before it) are the ultimate wafty vacuum. Over-engineered, low stressed motor. Should be good for another 100 years now, might need a bag or belt before then though
Online Dysonboy
Just wondering.
Why did you bypass the supressor? what exactly does that so?
