Author Topic: Hoover Convertible U1124A May 1961 - Stripdown and Refurb! (Dial-A-Matic)  (Read 13858 times)
Re: Hoover Convertible U1124A May 1961 - Stripdown and Refurb! (Dial-A-Matic)
« Reply #15 on: January 05, 2018, 11:33:55 pm »
And screwed down
Off to one side
As it's time for the hood!
First on is the release pedal, and the rubber pad needs fitting to the pedal
Then fitting to the machine
Rear wheels
Time for the height adjuster knob now
And bracket
« Reply #16 on: January 05, 2018, 11:37:58 pm »
Front wheels
Then it's time for the hood to be lowered down over the body of the machine
Then the two pivot points can be done up
Bag door now
Felt pad in, as well as the two felt strips that run up channels on the side. One of these was half out, which I think made the adjuster knob harder to turn
Diverter valve fitted
And the suction ducts screwed down
The knob can be screwed down now
Then finally the bag door can be screwed onto the main machine
« Reply #17 on: January 05, 2018, 11:40:13 pm »
Release pedal spring fitted
Then the wonderfully clean external hose can be fitted
Brushroll next
Strips in
And assembled fully with new bearings
Fitted
Baseplate fitted
Big scary spring fitted
« Reply #18 on: January 05, 2018, 11:45:03 pm »
External hose pushed fully home
Up top now, and the cable is fed through the strain relief and screwed down
And fitted
The handle can be fitted and screwed fully home, making it less wobbly than it was before
Cover clips on over the screw it seems
And by jove it's done!
That would have been the middle of October going by Charlie's birthday balloons, and come November I chose it for that month's vacuum!
Where it served a DC04 it's arse on a plate!
It was very good
« Reply #19 on: January 05, 2018, 11:53:33 pm »
Well, deeper pile carpet like my mums anyway. I did find a toolkit from my Hoover Freedom fitted it though, which was nice
Teamed with a Hoover BrushVac they make a good team!
However, November turned into December
And it was time to not use it anymore, however... In the intrim above, a chap called Jae from America gave me some lovely detailed instructions on how to REALLY take the motor apart, so apart it all came again!
Up top first
Straight in with belt spindle removal
Then off with the carbon brushes
Smash out the 3 pins on the other end of the motor
Then lever the end off
« Reply #20 on: January 05, 2018, 11:57:55 pm »
But (and I missed this last time), lever on the first bit, not the second and BOOM, out it all comes!
All laid out! Sadly the upper hidden fan wasn't really dirty as apparently they can be
But meh, we've come this far!
Inside here are 2 nuts
Undo those and the top black part falls off
These two springs keep stuff under tension, and releases the coil
I could also now get to the top bearings and pack it full of grease
Lovely! It's not done until it's messy!
That done, it can all go back together
With another blob of grease on the other end. I know it should be oil as it mates with a sleeve bearing, but I could not find my oil at the time...
« Reply #21 on: January 06, 2018, 12:00:23 am »
Job done, back in the motor goes!
But before I screwed it down, I had noticed that the suction from the tools was pretty lacklustre for it's wattage, so I helped it along by sealing up the motor housing with silicone
And then the inner suction channel
Just in case, and it did improve it! The motor sounds smoother too, although not quiet and low pitched like an equivilant dirty fan would be! It did knock the high pitched whine off though!
So there we go, although I'm not finished with it yet, I am for now! Bye
« Reply #22 on: January 06, 2018, 12:18:05 am »
 8)
« Reply #23 on: January 06, 2018, 02:52:04 pm »
Bazzing strip down.  :thumbsup:
I wouldn't mind a mint one of these in the museum actually. Shame about that front grille.
I spy a Dyson brush roll removal tool puller being repurposed in there..........
« Reply #24 on: January 06, 2018, 03:47:31 pm »
Yes, it's a shame about the grille, but the price was fair, and it's just one of those things! Do have a plan to improve it some more though!
Yep, the puller of the belt tool was just pointy enough to tap the 3 locating pins out!
« Reply #25 on: January 06, 2018, 04:56:11 pm »
I suppose a replacement front panel is like a left hand rear molar on a chicken to obtain?
« Reply #26 on: January 06, 2018, 04:59:41 pm »
Intact, yes. Broken but with some fins remaining, and a bit of cut and shut, in progress!
« Reply #27 on: January 06, 2018, 08:02:32 pm »
 :thumbsup:
Offline john116
Can't be 1961. They didn't come out in the USA until 1963, and the UK in around 1967.
