Author Topic: My dc14 has a very small nick in the wire. Is it safe to use?  (Read 16223 times)
« Reply #15 on: January 16, 2018, 04:31:56 pm »
Can we have a better picture of the damage please.
Offline bluebumble485
« Reply #16 on: January 16, 2018, 08:19:31 pm »
if you don't know you should not mess with electric ,it bites
Offline Dysonboy123
« Reply #17 on: January 16, 2018, 08:43:42 pm »
I get a error when I upload the picture.
Offline Dysonboy123
« Reply #19 on: January 16, 2018, 10:00:31 pm »
Would a dc07 cable fit a dc14? They look the same, don't they?
« Reply #20 on: January 17, 2018, 11:12:45 am »
yes
« Reply #21 on: January 17, 2018, 04:49:09 pm »
Quote
If you don't play you don't learn.
« Reply #22 on: January 17, 2018, 06:52:50 pm »
Very true... What's your age dysonboy123 ?
And don't forget to unplug it beforehand.  :dead-dyson:
Offline Sleaford White
« Reply #23 on: January 17, 2018, 10:00:27 pm »
what size heatt shrink do you use is a hair dyer hot enough never used it
I would say it's about 1.5cm. I use a paint stripping gun with a curved end attachment.
« Reply #24 on: January 17, 2018, 10:35:01 pm »
No pics but it's dead simple.
1. take off the switch cover (2 screws on back of spine).
2. Remove cable from switch and neutral connection.
3. Slide protective shroud down from broken area.
4. Measure the length of cable between broken cable and terminals, less than the area between grey insulation and terminals.
6. At the broken point CAREFULLY cut through the outer insulation ( I use a Rabii tool but in carfull hands a stanley knife will do).
7. Pull off the broken bit of outer insulation.
8. Measure the blue and brown wire. Add an extra cm and cut.
9. Carefully remove about 1cm of insulation from blue and brown wires and twist the copper together tightly and bend the copper in half and crimp on new terminals. Terminals are cheap as chips if ordered from China, however, I would recommend a proper crimping tool. A pair of pliers/mole grips is just not good enough
10. Re-route the cable and make sure the switch is in the "ON" position before fitting the the switch housing.
No charge!
Offline Dysonboy123
« Reply #25 on: January 18, 2018, 10:26:56 pm »
I'm 18. And don't worry, I always turn of the plug before starting any work on it.  :chuckle: :chuckle:.
Offline Dysonboy123
« Reply #26 on: January 18, 2018, 10:29:33 pm »
I might be changing the whole wire. Better safe then sorry. The wire has a weird lump on it.
Offline Dysonboy
« Reply #27 on: January 18, 2018, 10:46:09 pm »
Any dyson cable will fit any other dyson if you swap over the cable grommit on the machine.
Any 2 core (or 3 core with cut off earth) thats 1.5mm I think? will fit any dyson providing you put new crimp spades on and swap over your cable gromit.
A DC07 cable will directly fit a dc14, vice versa because they share the same gromits.
Offline Dysonboy123
« Reply #28 on: January 18, 2018, 11:50:33 pm »
Is there any dc14 cables for sale?
« Reply #29 on: January 19, 2018, 01:19:19 pm »
Not really, spades and lengths differ across models. And if you fit the wrong one it wont wrap right.
Hundreds of them >here<.
