Hello again, sorry for late reply, I have been away for a few days (unexpectedly). I did what you advised and jetted the cyclone through, the machine is now definately working better and is not cutting out as before, there is also more movement in the bin. However, although the suction has improved, I am still doubting that it is as strong as it should be. (I have an old Dyson DC04 and the suction on this is stronger than the DC07). I renewed the internal hose when I renewed the filters and motor so I can't figure out why the suction is'nt as good. I would be grateful if you have any more advice on this. Regards and thanks, Mikee.
Hi, the suction at the wand seems fine, so it's just at the bottom really. Regards Mikee.
Hello again, I will check everything out that you advised. Once again, thank you very much for all your help, I will certainly recommend your website and forum to all of my friends. I am only sorry that I bought spares for my Dyson elsewhere before I found your site, otherwise I would have purchased the spares from you. Regards, Mikee.
