Author Topic: Have I got a clutch problem???  (Read 4432 times)
Re: Have I got a clutch problem???
« Reply #15 on: February 04, 2018, 03:46:43 PM »
I'll get the belts ordered and get down to it as soon as I've got my house move over with (and recovered from the experience!)
Once again, thanks...
Videos and full instructions >>here<< Duncan.
Offline Dysonboy
« Reply #16 on: February 05, 2018, 12:31:35 AM »
Want to add. The older "N.P.D" Clutch markings instead of the later "OFF and ON" markings, For some reason the markings are not quite aligned with how the clutch operates so it only goes to half through AUTO intead of making it all the way to D.
Quote
It moves about half way down towards the Auto 'spot', so whatever mechanical link exists appears not to be broken.
To be honest, I have no idea how far it moved originally - it worked superbly, so I never thought about it...
Thats normal on the older N.P.D markings as you have described. The clutches only go half in AUTO.
Quote
The know should be on the "on" position when the head is kicked down, if it only goes halfway then the clutch isn't engaging properly to the on position
On the later DC04s, and all DC07s onwards etc. marked with ON and OFF then yes it should go fully round to ON, If its the older N P D markings then the clutch only goes round to half way through AUTO and not to D. This is because the markings on the cleaner head are slightly off for some reason.
I had the same problem with my DC04 Absolute when I had it. Took me a while with a spare ON and OFF marked cleaner head to understand that NPD heads are slightly off marked. The AUTO is slightly larger..
Hope I helped!
Offline duncan_a
« Reply #17 on: February 05, 2018, 01:18:25 AM »
Dysonboy's reply was interesting...
This might mean that, as the brushes aren't really doing their job (but there's no 'clatter' from the clutch), I may be suffering from belt-slip, rather than a clutch problem.
As I appear to need to partly dismantle the clutch to change one of the belts, I might just as well give it a service and replace the 'white roller' while I'm in thete.
Offline Dysonboy
« Reply #18 on: February 05, 2018, 01:25:02 AM »
Id deffo say belts are slipping. The white wheel is also a good idea to replace as you said.
DC04 Spare Parts
