take the rod off the top one screw then there is one side flat slide down between cyclones then tap job done
Quote from: bluebumble485 on February 26, 2018, 12:15:00 AMtake the rod off the top one screw then there is one side flat slide down between cyclones then tap job doneI tried it but the same "screwdriver" the T one does not let me take the screw out from it, do you know which one I would need as I don't I have the right one.
Quote from: dragoncurt on February 26, 2018, 08:48:23 PMQuote from: bluebumble485 on February 26, 2018, 12:15:00 AMtake the rod off the top one screw then there is one side flat slide down between cyclones then tap job doneI tried it but the same "screwdriver" the T one does not let me take the screw out from it, do you know which one I would need as I don't I have the right one.To remove the push rod from the cyclone top handle is a T15.
Manchester Vacson
