Author Topic: Dyson DC24 all surface model  (Read 628 times)
Offline edges
« on: March 06, 2018, 07:42:03 PM »
I have a DC 24. A while ago the brush head stopped working and would not reset using the red button. I purchased a genuine Dyson replacement brush head and fitted it. Second time of using the cleaner there was a flash in the brush head & it stopped working and would not restart. There was no red button on this unit.  I checked the output at the 2 pin socket where the brush head connects with the cleaner body and it was a constant 230v AC. It was only used once on a lightweight carpet in a small bungalow. No threads, hair or anything else blocking the brush bar. Any suggestions as to what caused the new brush head to fail so quickly?
Re: Dyson DC24 all surface model
« Reply #1 on: March 06, 2018, 09:18:42 PM »
This was a brand new head and not a "reconditioned" one or similar from an ebay seller or suchlike?
Offline edges
« Reply #2 on: March 06, 2018, 09:46:33 PM »
Yes. This was a brand new, genuine Dyson head, sealed in box from an Amazon supplier. I returned it and got full refund but am wary of buying another in case there is a fault elsewhere which caused the head to fail.
« Reply #3 on: March 06, 2018, 10:05:23 PM »
There was a batch of faulty heads around not so long back.
I can't think of anything that would cause a motor to flash in a new head as long as the 230v supply is constant when the machine is reclined and wiggled about. Sounds like you got a faulty head.
Offline edges
« Reply #4 on: March 06, 2018, 10:09:43 PM »
Thanks.  The head was cheaper than on a number of other sites so maybe dealer had acquired suspect batch cut price. I will order another through link on here.
