Author Topic: DC33 gasket  (Read 1516 times)
Offline Dysonboy123
DC33 gasket
« on: April 22, 2018, 12:08:18 AM »
I installed a new dc33 gasket on the cyclone ( a Qtex one) the one which is prone to damage . Once I installed and used the machine I can hear a very small hiss from the cyclone. Is it a problem?
Re: DC33 gasket
« Reply #1 on: April 22, 2018, 01:44:59 PM »
Check around the perimeter, do you see any gaps? It could be hissing due to the suction leaking as a result of the seal not being fitted correctly.
Offline Dysonboy123
Re: DC33 gasket
« Reply #2 on: April 22, 2018, 02:21:59 PM »
There's no gaps. Could the seal need replacing again? I fitted the seal properly and tightly.
Re: DC33 gasket
« Reply #3 on: April 22, 2018, 04:05:22 PM »
Are you sure itís a hissing noise? The cyclones can be howling when theyíre all clean, and youíre not used to the noise since itís a clear air path, so itíll make some noise
Offline Dysonboy123
Re: DC33 gasket
« Reply #4 on: April 22, 2018, 11:33:06 PM »
I noticed that one of the seal bit isn;t on the cyclone. Can I use it like it is or will it damage the seal?
Re: DC33 gasket
« Reply #5 on: April 23, 2018, 02:20:05 AM »
TBH itís best if you make sure the seal is on right and itís sealed all the way around with no gaps
Itís like that for a reason, so no air escapes
Offline Dysonboy123
Re: DC33 gasket
« Reply #6 on: April 23, 2018, 03:18:51 PM »
I've ordered another torx 15 screwdriver as I've lost mine somewhere  :'( :'(. It's expected to arrive between Wednesday and Thursday. Can I still use the machine?
Re: DC33 gasket
« Reply #7 on: April 23, 2018, 09:01:49 PM »
I wouldn't, it could be dangerous.
Re: DC33 gasket
« Reply #8 on: April 24, 2018, 12:37:31 AM »
I've had one of the edges bend in whilst assembling before without realising, doesnt take much!
Offline Dysonboy123
Re: DC33 gasket
« Reply #9 on: April 27, 2018, 01:10:02 AM »
I've tried so many times to make it perfect but it keep making a very little hissing sound.
Offline Ampere Husky
    • Twitter
Re: DC33 gasket
« Reply #10 on: April 27, 2018, 04:23:26 AM »
Worst case scenario is if it's a leak between chambers you may have to wash the filter a bit earlier than normal, or if it's a leak from the outside, you'll have slightly less suction.
AM01 silver/grey (12"), AM04 white/silver, DC01 Absolute+ (ametek), DC01 Limited (ydk), DC03 Absolute+ (yellow/purple), DC04 S/L, DC04 Absolute+ (purple/lime), DC07 Origin, DC07 Animal, DC14 Allergy, DC14 Animal, DC16 Animal, DC24-i, DC27 Animal, DC35 Multi-floor, 2012 AEG Ultrasilencer (gloss blue), Numatic Henry (old style 2-speed with red push switch on top, and green hi/lo rocker switch on the back)
USA: DC33 Multi-floor
Offline Dysonboy123
Re: DC33 gasket
« Reply #11 on: April 27, 2018, 07:52:22 AM »
I'm trying to make the seal fit properly to stop that hissing sound. Any advice on how I could fix it?
    • Twitter
Re: DC33 gasket
« Reply #12 on: April 27, 2018, 10:52:53 AM »
               Maybe coat the channel the gasket sits in with some sealant, wipe up the excess with a mild degreaser, then pop the gasket and manifold back on?
                   Unless the gasket is uneven or cracked, which sealant would temporarily stop.
                   I cant think of another reason why it would leak.
