Author Topic: Sebo X4 'Extra' - Stripdown and Refurbishment  (Read 11092 times)
« on: May 02, 2018, 12:03:59 AM »
A long, long time ago now, I picked up this down on it's luck Sebo X4!
And a while ago, it got the usual treatment, so here we go!
Utterly filthy inside, but a new bag had been fitted, which was nice
Some ominous looking gaffa tape on the wand though
As in the above before video, I cut the carbon filter up for a laugh/to make it work a bit better short term, which made a bit of a mess
And after using it for a bit, the stripdown commenced! I had 'borrowed' parts from it though to fix the X1 I wrote about a while ago, that I tried stripping down things that did not want to be stripped down and failed, so The Gaffer from these very pages helped me out with some nice used parts, which are not fitted during the stripdown, hence the wheels and brushroll out below.
Anyway, it came into the house in bits as thats how I stored it in the shed as it fitted in more easily
Bag door first
The bag holder needs to come out
The safety lever that stops the bag door closing with no bag pops out, along with its little spring
Then the whole assembly slides down and off the orange rear of the main opening handle
Re: Sebo X4 'Extra' - Stripdown and Refurbishment
« Reply #1 on: May 02, 2018, 12:09:51 AM »
Behind all that, a cover unscrews that holds the orange lever in place
It wiggles free of it's captive prison
There are 2 screws at the bottom of the bag door too
Which hold the front trim on. I could not get this off at this stage so gave up through fear of damage, however whilst washing it, it fell off! Turns out it slides on from the top...
Time for the handle now, the cable is released
And the handle is removed
One screw holds the hand grip onto the shaft
Then the hand grip pulls up slightly, then once clear the rear part comes away
To remove the cable, first we undo the clamp, noting the totally over complicated wiring arrangements
« Reply #2 on: May 02, 2018, 12:18:09 AM »
The cable can be unscrewed from the 2 switch terminals and pulled free of the oppressive regime of the handle
One little issue the machine had was a perished cable exit guide.
At this stage, a perfectly acceptable solution is to chop the offending segment off, but only if it's near the top. You need a new grommit if it's totally past it.
The wires running off to the bottom of the machine are spade terminal'ed onto the base of the switch. Once unplugged the rest of the hand grip comes away
Within the plastic hand grip is a little grounding strap that connects to the metal handle. Once unhooked along with the neutral wire, it pushes down slightly, gets unhooked from it's little plastic holder and can then be pulled out
The switch pushes out of the handle after removing the outer plastic trim
The rest of the metal handle contains the main plug to the body of the machine. This pushes out, and can be a real fluff trap
No way of dis-assembling this, and blowing the fluff out doesnt do it, I find 5 minutes with a pin picking the chunks out the best way, you'll be amazed at how much is in there! Or just don't bother as you don't see it when back together, your call really!
We can move on to the bag housing now. The inlet gubbing is hiding behind this housing, which unscrews and lifts off
Remove the hose clip first though otherwise it won't pull out and free of the machine
Like so
« Reply #3 on: May 02, 2018, 12:24:04 AM »
There is a metal bracket that slides into the side of the hose inlet tube, it's reason to exist I'm not too sure of actually...
The bag seal lifts off
We can now lift out the other side of the handle plug
Then the cable clamps need removing. The top two are simple, the lower one holds the second safety device, which stops the bag door fitting without a filter in place (which is easily bypassed, as it is here...)
All removed
Underneath the bag housing, where the bag housing meets the motor housing is yet another plug that carries the wire across another removeable section
Two screws this time and out it pulls. But, the wire won't release yet. You need to push the 2 male terminals out of the top plug before the wires will pass out
The lower cord hook/carry handle unscrews
Then the two halves of that seperate, along with the 'latching' spring
« Reply #4 on: May 02, 2018, 12:30:27 AM »
Nestled right up top is the locking assembly for the handle. This prises out quite easily with the removal of a circlip, which just pushes off
Let's get the crevice tool out of it's holder now
And remove the two tool holder clips
Back to underneath now, and we need to remove all the screws you can see
Then the bottom cover pops/prises/levers off fairly easily, once you push the big yellow button in so the outer skin can pass over it
Inside we can see the latching mechanism that secures the 2 parts together
Which just lifts out
« Reply #5 on: May 02, 2018, 12:35:26 AM »
And that's the bag housing done! Slight tangent now for the brushroll, which is already removed in my case
Remove the copious amounts of crap
Then the rear wheels
I took the end caps off to clean the fluff from within, but went no further. This is where I went wrong last time...
We can now move on
And this is where it got messy
First the post filter cover came off
Then it's actual brushroll came out, which is so worn it puts the brushroll light on, so that went in the bin
Bit of a difference
The little bit of blue trim pops off the brushroll end cap/latch
« Reply #6 on: May 02, 2018, 12:40:22 AM »
We can remove the motor hood now
The post motor filter cover latch is held in with an screw
The brushroll release button, it's springs and the bumper lift out
We can unscrew the secondary PCB after unplugging the 2 ribbon connectors
Then the belt cog mechanism can be removed, along with the motor to cogs belt
The recline stay brace and it's cover slide out, note also a bit of anti vibration foam has fallen off too
The height adjuster motor unscrews and lifts out, bringing the centre wheel with it
The power PCB can be unplugged
« Reply #7 on: May 02, 2018, 12:44:15 AM »
And then unscrewed
The brushroll drive cog is unscrewed
And removed
Now for the motor, and we remove the rather distorted cover, this thing's been HOT before...
The motor lifts out now
It's a Domel unit, not familiar with their work though
We can remove the 2 screws holding a trim piece for the pivoting mechanism now
Then that whole unit just lifts out too
Nice build up around the bottom felt seal
« Reply #8 on: May 02, 2018, 12:48:37 AM »
The offending filthy piece just lifts out
The motor side of the pivoting housing has 2 fabric seals, which lift out for cleaning
On the inner piece, 2 plastic spacer rings pull out
Inside that is the last part of the spinal wiring, and another cable clamp to remove
Remove the spade terminals from the covers and the wires pull out
The locking tab for the recline mechanism slides fully out with a bit of force
Some lovely mould forming...
2 screws and a little cover releases the blockage inspection port from the underneath of the chassis
Nearly there, baseplate now!
« Reply #9 on: May 02, 2018, 12:51:19 AM »
I think this machine has led a hard life...
The front metal strip pops out of the chassis, bringing a nice layer of crud with it
The 3 stay bars for the brushroll to stop it fully sucking light flooring up pull out once cracked free of their crud prison
And there we are! Tomorrow night (or another night...) we shall re-assemble it and see how it came out. Stay tuned!
« Reply #10 on: May 05, 2018, 10:56:28 PM »
Right, where were we? Ah yes, all ready for re-assembly!
And we shall start with the brushroll guards, which came up nicely with a light polish!
Fitted
The front baseplate can go on now
Then the rear one
The blockage flap next, and with the little axle removed all the grit can be flushed out, making it much smoother in operation!
It sits nicer too now its not being held open with accumulated fluff
« Reply #11 on: May 05, 2018, 11:01:17 PM »
The securing blocks can be screwed down
Pivoting mechanism now, which is now shiny and white, and not full of moldy dirt
The recline lock slots back in
The two parts that hold it all into the machine have the washed and fluffier/more air tight felt strips re-inserted
The little felt seal is placed back into the chassis
The wires can be run back through the unit and slotted into the chassis
And screwed down
The motor gets the end seals fitted and dropped into place
Oddly the housing is melted quite alot, but the wires still fitted into the little cutout for them
« Reply #12 on: May 05, 2018, 11:06:04 PM »
And the top motor cover screwed into place. My gosh it is warped isnt it! Motor is in good health though, which is a bit strange
Brushroll drive cog now
Fitted, with the first belt
Then the middle cog assembly is fitted, along with the motor to middle belt
The power PCB drops into place now, and the wires connected
Height adjustment module fitted, along with the center wheel
Then the control PCB is fitted and plugged in
The motor spindle guard and stabiliser bar are fitted
« Reply #13 on: May 05, 2018, 11:10:47 PM »
Brushroll eject button and it's 2 springs in place
Post filter cover latch screwed back into the hood
And the hood can be refitted
The cleaned up brushroll inserted
Rear wheels screwed in
Post filter cover fitted (sans filter for now, I forgot to get it out of the shed at this juncture)
Moving on up, the securing bar is refitted
And the cover part is slotted on and screwed in
Tool holders fitted
« Reply #14 on: May 05, 2018, 11:15:25 PM »
Way up top now, the handle latch is refitted, along with its circlip
Lower cord hook/carrying handle re-assembled
And fitted
Back to electronics again, the very bottom of the middle cable run is fitted and screwed into place
The cable run up and clamped down
Then the top wiring is placed, and the bag entry/hose entry port is fitted and screwed down
The wiring is run through the handle
Switch fitted
Mains cable inserted into the handle, and wired up to the switch along with the other wiring
