Why yes it is and I have totally missed that screw.
Will look at that tomorrow.
Thanks again
two are visable looking from inside of cleaner head with brushroll and brushroll housing removed and third screw which many new people forget or dont realise is under the U-Bend and there is a hole in the chassis, a long t15 driver down their and thats the final screw. it then pulls off, you can remove fan belt (that what I call it anyways - from motor (fan) to clutch) cleaner head off, 1 screw, switch housing off, remove inner cable from switch and neutral junction, pull cable out of rear of chassis, four torx 15 screws around the motor shroud then the hole thing pulls off, (we remove cable to make this much easier) pull off motor housing shroud, then the fan cover pops off with a large flatblade in all four tabs (try not to break them, not end of world if one goes) then motor will pull out. Washing liquid or some other lubricant on the seals helps with the seals otherwise its a pain in the behind. Need any more help
