Author Topic: DC24 PCB BOARD  (Read 9681 times)
Offline dsam
Re: DC24 PCB BOARD
« Reply #15 on: September 03, 2018, 03:32:42 pm »
No, check for a dc voltage at b.bar motor end about 330 volts dc
Re: DC24 PCB BOARD
« Reply #16 on: September 03, 2018, 03:38:54 pm »
Only you can do that, you need a volt / ohm meter to test the bridge rectifier & 1 ohm resistor as well as any other components on the board.
was the yoke cable ok ?
I have a 24 on the bench actually for service so will take a couple of pics... if required
