Author Topic: DC40 Yoke cable replacement  (Read 15700 times)
« on: August 31, 2018, 07:14:26 PM »
Often asked, how to change the dc40 yoke cable, usually the cause of no beater function - but a faulty motor can also be the cause so check the output first with a voltmeter (set to dc) and look for 320v.
ila_rendered Snapped white cable on the yoke loom just spotted !
Re: DC40 Yoke cable replacement
« Reply #1 on: August 31, 2018, 07:50:11 PM »
« Reply #2 on: August 31, 2018, 07:57:05 PM »
« Reply #3 on: August 31, 2018, 08:05:25 PM »
« Reply #4 on: August 31, 2018, 08:11:38 PM »
Getting the cover (marked with arrows) aligned to slide on is a bitch to do.
« Reply #5 on: August 31, 2018, 08:24:06 PM »
The rest is easy enough, refit filter, ball covers not forgetting the two washers.
The whole procedure isn't hard to do, just fiddly.
I finish with a floor test and finally an electrical safety test, with appropriate label on the plug with my name and phone number for the next time it fails !
Hope you find it useful, my first time doing one of these posts, and until you have done one you won't realise the time and effort required (Beko sam i applaude you )   :bow:
