Author Topic: New Members - How did you find us?  (Read 119883 times)
Offline Adam
Re: New Members - How did you find us?
« Reply #330 on: June 05, 2019, 02:43:18 PM »
My Dyson 28c needs the power switch replacing, after removing every screw I can see I have split the case but something is stopping me removing the top casing to get to the switch. I cannot find any info on actually dismantling this model. There must be a screw I cannot see. HELP PLEASE - I have a replacement switch in my hand!
« Reply #331 on: June 05, 2019, 02:44:09 PM »
Welcome Adam, I've replied your topic on the subject.
Offline J6o6h6n6
« Reply #332 on: June 05, 2019, 07:19:05 PM »
I googled “ how do I repair a Dyson DC 25 rotating head that no longer rotates”
Your site came up as one of the several options.
Thank you.
« Reply #333 on: June 06, 2019, 07:06:17 PM »
Thank you.
Welcome. You'll find a wealth of knowledge here.
Offline J6o6h6n6
« Reply #334 on: June 07, 2019, 01:40:40 AM »
You’re absolutely right. Today I replaced the yolk wiring loom, well I took  the machine apart and rewired the yolk with a more substantial wire. It appears to have worked, the brush head was only working intermittently, now working well. Followed material on this site to do this. So great and thank you.
Offline Abbi
  • Help! 😜 DC15 My nemesis
« Reply #335 on: September 15, 2019, 06:49:38 PM »
Hi!  🕵 I found you by accident. Don't you love Google! 😉 I hv a DC 15. I've had it about 5 or 6 years. My mother bought it brand new. Not sure when but I believe she had it as if not longer than myself. I've taken it apart 100 times to clean it. I went a little deeper this time as I had loaned it to a friend and was disappointed when I got it back. Anyway, I can't figure out how to get the brush bar motor back the way it was. Actually it's the wires. I can't get them to fit right. Usually I'd take pictures (I did, just not of the 1 thing I needed a picture of)  Anyone hv any ideas?
I just want my DC 15 back together so I can vacuum my house. 😬🤞😂
« Reply #336 on: September 16, 2019, 01:51:35 AM »
Welcome Abbi, make a fresh topic with more detail as the DC15 is a very complex machine.
Offline Abbi
« Reply #337 on: September 17, 2019, 12:13:11 PM »
I'll try my best. Thank you.
Offline TheDonk
« Reply #338 on: December 06, 2019, 01:28:29 PM »
Hi, found you on Google - where else?
I have a SEBO X4 which, after being used for years, recently and without warning, appears to have burnt its motor out.  I bought a replacement motor from you which I fitted yesterday.
Now I have a problem!!
Although the motor is spinning freely and it appears to work as long as there is no load on it, as soon as is it used on even a hard floor, so there is only a light load, there is a distinct burning smell as if the brushes are arcing badly. Using it briefly on a carpet makes it a lot worse.
I'm concerned that the burnt out motor was the symptom of another problem and unless that is sorted before we use the SEBO, this motor will burn out too.
There doesn't appear to be mechanical issues so this has become a real puzzle!
Does anybody have any ideas?
Offline VacManEd
« Reply #339 on: December 06, 2019, 03:22:25 PM »
Hi,
I put "vintage vacuum cleaners" into a search engine, and this website came up.
I have a few old vacuum cleaners etc to dispose of , and I would like them to go to a collector if possible.
I can send details and pictures.
Regards.
Ed.
Offline andy218
« Reply #340 on: December 06, 2019, 07:12:21 PM »
Found you via a bit of google and Youtube searching for info on refurbishing my DC14 Blitz and an old Vax121 that has given faithful service for years but now groaning a bit.  Hello there  :tiphat:
« Reply #341 on: December 07, 2019, 11:21:31 PM »
Greetings Andy.  :tiphat:
Offline Pietree
« Reply #342 on: December 22, 2019, 10:24:01 PM »
Hi, I found you in my hunt for help to fix my sebo x4.
It seems to be stuck in the raised position and the check brush and bag clog lights are flashing red. I have checked thoroughly for clogs (and removed one) and have replaced the filters but it’s still stuck and flashing.
Any ideas?
« Reply #343 on: December 22, 2019, 11:11:25 PM »
Any ideas?
Welcome.
Make a fresh topic in the Sebo room.
« Reply #344 on: January 14, 2020, 10:33:25 PM »
The post by DavidB has been moved to First Generation "The Ball" Dysons as it wasnt an introduction.
https://manchestervacs.co.uk/DysonForum/index.php?topic=4082.0
