Dyson Models
Dyson DC14, DC17, DC27, DC28 and DC33
DC14 has faulty something
Topic: DC14 has faulty something (Read 5181 times)
cunundrum
December 06, 2018, 03:58:21 pm »
When I am using cleaner it stalls and restarts (switches off and on) as it's being pushed and pulled across carpet
I've installed new switch but fault still there. Any ideas, guys?
Madrat
Re: DC14 has faulty something
December 06, 2018, 07:48:14 pm »
Brake in the cable to the switch, or from switch to motor.
MVacs
Administrator
December 06, 2018, 08:00:31 pm »
Mains lead possibly. It wants meter testing really. It's almost never the switch on a Dyson.
Sebo repairs in Manchester
Dyson repairs in Manchester
Sebo spares in London
cunundrum
December 06, 2018, 08:53:46 pm »
Dusted off meter and checked continuity of the "in-coming" mains cable.
Live
is good from plug through switch (switch working fine too).
Neutral
, checked from plug (N) to spade terminal at end of mains cable (separated spade terminals inside small black, hinged "box"). Nothing, no continuity
Electrical things are a bit of a black art to me and this is where my knowledge lets me down. Does this mean a problem in the neutral side of this cable or have I just not understood the circuit?
Madrat
December 06, 2018, 09:12:38 pm »
Neutral wire has a brake, it is usually where it enters the machine, or just where it comes out of the plug. you can most of the time just cut the cable shorter (or replace plug) or if you cant fit new terminals get a new cable.
ryevac
December 06, 2018, 09:23:25 pm »
Yes sounds like open circuit on the neutral, cut off the cable at entry point, around 7 inches then check again with meter.
If still open circuit then it could be a break in the plug end of the cable.
If so cut off 7 inches and recheck continuity, if ok fit a quality 13a plug. If not then the break could be further down the cable so just fit a new one.
Generally, when tracing a cable fault, just keep the probes on either end of the cable in question with crocodile clips and then wiggle the cable till you see the meter reading correctly if its intermittent.
The other method, is using an oscilloscope, high speed schmitt trigger pulse fired down the cable - measure with scope and on the trace you will see a little spiked peak, that will visually tell you where the break in the cable is roughly - ok for finding a break on a 100ft cable on an aircraft, but really not practical for a hoover
cunundrum
December 06, 2018, 09:31:58 pm »
I fancy using the High Speed Schmitt Trigger (if I knew what it was). Or is this just a load of tech bollocks
ryevac
December 06, 2018, 09:50:35 pm »
It's an olld 74ls14 ttl chip configured with one of it's outputs fed to imputs so it oscillates if i remember right.
Used by the raf many years ago, (Time domain reflectometery ) sorry just been geeky... i attended a lecture in the 90's, a guy called dave smith did the presentation and was very interesting
https://en.wikipedia.org/wiki/Time-domain_reflectometer
cunundrum
December 07, 2018, 09:52:06 am »
Not geeky. I could see its application for fibre optic cables in ducting under the street, in fact any cables!!
Talking of cables: fired up cleaner, back and forward - no problem. Typical. Waggled cable about until cleaner cut out. This time so did the ring main! Cut cable as suggested and tested for continuity. No signal from neutral so assumed break to be somewhere in main length of cable. Ordered new cable from manchester.
Thanks guys and here's hoping!!
ryevac
December 08, 2018, 12:09:11 am »
new cable should sort it and last another 15 years...
December 12, 2018, 12:05:08 am »
It's VERY similar to the DC07 cable change
//www.youtube.com/watch?v=yAJePCxHLmg
Mind you get a cable with the cord exit guide and crimps already fitted if your not too confident about doing that yourself, plus you'd need to buy a crimper and many crimps to do the job which you would have lying around forever more!
Sure Mvacs could sort you out a plug and play cable for happy money!
cunundrum
Reply #11 on:
December 12, 2018, 01:53:10 pm »
Hi Guys
Problem solved. Machine running well with no hicups.
I did buy and install the new cable with crimped spade terminals. I used old cable guide. Fitting was quite easy.
Thanks again and keep up good work on this forum.
ryevac
Reply #12 on:
December 12, 2018, 10:57:00 pm »
Dyson Models
