Author Topic: DC18 dirty as muck  (Read 1955 times)
Offline gilbo
DC18 dirty as muck
« on: January 23, 2019, 03:28:22 AM »
Folks I was able to acquire a DC18, for a great price free, but it was filthy. Still runs. I'm in the process of cleaning it up. My question is this part able to be removed so I can clean it out.
* DC18-page3 copy.pdf (102.72 kB - downloaded 151 times.)
Re: DC18 dirty as muck
« Reply #1 on: January 23, 2019, 02:04:00 PM »
That is part of the duct. So it can only be cleaned if you strip the full machine down.
« Reply #2 on: January 23, 2019, 07:58:10 PM »
To do that properly you've got to strip the whole thing off and wash the chassis!
Can you get to the other end of it? (never had an 18 before, well I have, for 4 years but done nothing with it!) If so, a large flexible wire bottle brush, and drape a few dettol wipes over the top and give it a good rodding might see it a bit cleaner.
You'll want to get to the other end though, because otherwise youll push all the dirt straight into the motor fan, and youll have to strip it right down anyway 20 seconds after turning it on to have the motor out to wash the fan!
Offline Jess
« Reply #3 on: January 24, 2019, 06:06:35 AM »
I just did mine I got for free last week. Yep dirty. The change over would not budge due to all the animal hair and human, could not get it out without total teardown.
Word of warning if you do it, watch for the two screws that hold the microswitch in. There is one screw on the small cover and its not problem and safe to remove.
But once exposed there are two more and the top screw holds the other end of the foot pedal spring behind the microswitch plastic casing. Once that screw is off the spring will release (as will the microswitch when its cover is removed)  and possibly the small plastic piece that was held on with the top screw that the spring attaches to in behind, on the backside. Reassembling- Putting the foot pedal spring back on, remove it from the pedal and put it on behind the microswitch first.
Other than that it was not too hard to do. Tho last two I did were DC25's and I went in expecting similar and they are quite different.
 In the DC18's favor the wiring plastic loomy thing (sorry for not id'ing with right terminology) does not need to be removed to get the motor out. Bonus. The loom is under the motor behind the plastic casing and all one needs to do is disconnect the two leads into the motor.
 I blow all motors and filters out with air compressors. Figure that far into it, might as well go lil bit extra.
 Good luck!
oh..As to that clear plastic foot plate, try to be gentle. I think I broke mine with all the maneuvering with the other two pedals, tho perhaps it was ready to go anyways (I like to tell myself ..nah...wasnt me who broke it :'(
There is a partial teardown on site by markcorrado1  https://manchestervacs.co.uk/DysonForum/index.php/topic,408.msg4636/highlight,dc18.html#msg4636
and also here Helpful Colin  https://helpfulcolin.com/?s=dc18
Other than that I could find no other info on line when I was working on mine and ran into the spring attach issue behind the microswitch - that darn lil piece of plastic and where the heck that piece was supposed to go back into was a pain.
It's worth the fix. I love this DC18 and prefer it over the DC25 even tho it has less air watt, it is impressive and waaaa..aay more agile and easy to use.
addendum, you could have a look at Beko1997 teardown on the DC25, He replied to you above. If I remember correctly he has photos here on site and utube vid also. The models are not exactly the same, but if you haven't been inside a Dyson before, there is lots that is similar and will give you an idea about the foot pedal spring and the change over valve. General idea about it all and then figure it out from there. The DC18 is easier as you will not need to muck with putting wires back into the motor loomy thing, so don't let that deter you when watching Becko's teardown.
Beko maybe you need to teardown that DC18 you have  & post a lovely photo montage and a vid like your awesome DC25 resources :whist11:
Offline gilbo
« Reply #4 on: January 25, 2019, 02:50:17 AM »
Thanks folks, that's what I was hoping I didn't have to do.
It's not hair and debris, I cleaned that out from the head and there was plenty of that. Teardown of the head was pretty straight forward. it looked like they vacuumed something wet, when it dried it was all white.
I'll finish it up this weekend, hopefully.
Offline gilbo
« Reply #5 on: January 26, 2019, 10:06:50 PM »
Thanks folks for all the help, got it all cleaned up.
Jess the links you gave, were exactly what I needed. Took me longer to clean it up than it did to take apart and reassemble.
Now the Mrs. is a happy camper since she has 2 Dyson and doesn't have to lug the DC17 upstairs.
Offline Jess
« Reply #6 on: January 27, 2019, 01:38:51 AM »
That's so great it worked out for you!
Happy to pass on links.
It is truly amazing & wonderful, the time & effort people have put in creating those resources of pic's & vids and making available for access ;)
Perhaps the DC18 will become your wife's favorite- It is mine so far - Tho my stable of Dysons is pretty slim.
