Author Topic: DC40  (Read 466 times)
Offline plugcoupler
DC40
« on: February 03, 2019, 04:15:13 PM »
Hello all, 1st post etc
The brush on my DC40 isn't spinning.
Ive had the brush assembly to bits and cleaned it, nothing.
The best i can get coming out of the power connector to the brush assembly is just over 5V?
Its a DC motor on the brush assembly?
Any ideas anyone?
Re: DC40
« Reply #1 on: February 03, 2019, 05:17:57 PM »
Yes it will most likely be >>this loom<<. They are known for it.
You need to see a DC (not AC) output of about 300-320v. PCB is a possibility but that loom is more likely.
Offline plugcoupler
Re: DC40
« Reply #2 on: February 03, 2019, 07:16:46 PM »
Thanks, and thatís in the ball assembly, opposite side to the filter?
Re: DC40
« Reply #3 on: February 03, 2019, 07:24:14 PM »
There is a photo of it in >>this topic<<.
There is a strip down topic in the room stickies if you fancy DIYing it.
Online ryevac
Re: DC40
« Reply #4 on: February 03, 2019, 07:56:54 PM »
https://manchestervacs.co.uk/DysonForum/index.php/topic,3685.0.html
If as mentioned dc high voltage is there then motor at fault, if not... then loom or pcb at fault.
The only failure is not to try.
Offline plugcoupler
Re: DC40
« Reply #5 on: February 03, 2019, 10:05:36 PM »
The loom doesnít look damaged, belled out and 0.2ohm on each core. So it must be the pcb?
Online ryevac
Re: DC40
« Reply #6 on: February 03, 2019, 10:48:19 PM »
always wise to give the loom a waggle when checking on the meter.
If you have no voltage to the motor and you say the loom is ok, then either the motor or pcb at fault.
You could also check for 240v ac~ input to the pcb too to confirm cut out and axis switches are working.
It's hard to diagnose through the keyboard, in the real it's easier to find fault.
