Author Topic: Dyson V6 cuts out in max mode, blue flashing light  (Read 518 times)
Offline Browntoa
« on: February 15, 2019, 05:29:19 PM »
I thought it might be blocked so dismantled , cleaned inside cone and head and got loads of muck out.
It runs for about 10 seconds on max mode , the round blue circle starts flashing and then it stops working with flashing blue led. You need to connect to charger to reset.
Runs fine without stopping when not in max mode.
If I block suction it starts pulsing as it should and stops . If I release trigger and then press again it starts up as it should.
Does the same with or without filter and cannister on unit.
I've removed the battery when it's stopped working , left a while and then reconnected . Still flashing blue afterwards and needs connection to charger to reset.
I'm sort of thinking it's the battery but have not got a spare to check.
Re: Dyson V6 cuts out in max mode, blue flashing light
« Reply #1 on: February 15, 2019, 10:39:21 PM »
I would be looking at battery, due to the device running normally in low power mode.
Offline Browntoa
« Reply #2 on: February 15, 2019, 10:48:31 PM »
Cheers , what I thought
Will see if I can borrow a battery
I've noticed Dyson no longer sell them on the website
« Reply #3 on: February 16, 2019, 12:41:41 PM »
Luckily mine started to show similar symptoms as yours, just before the 2 year warranty expired.
Dyson replaced it F.O.C fortunately, and resolved the problem.
Offline Browntoa
« Reply #4 on: February 16, 2019, 12:59:23 PM »
Well after 2 battery votes just ordered a replacement from eBay from 100% feedback seller
Will come back and update
Offline Tim100
« Reply #5 on: February 16, 2019, 02:42:03 PM »
Agree on battery they go regular at about 2to 3 years old
Offline Browntoa
« Reply #6 on: February 17, 2019, 11:46:05 AM »
Had a reply back from Dyson about no battery available , they claim they are but you have to ring customer service. I'm assuming hard sell on engineer visit
Offline Browntoa
« Reply #7 on: February 19, 2019, 10:11:56 PM »
And can confirm new battery was the answer.
Thank you all
« Reply #8 on: February 20, 2019, 01:37:00 PM »
 :thumbsup:
« Reply #9 on: February 20, 2019, 08:09:27 PM »
Yes there is a shortage of genuine ones and Dyson are hoarding what they have to fulfill warranty claims. None are available to the trade at the moment. There's been a drought for months.
We've had some good 3000 mAh in from China to keep up with shop demand (it's not a line we sell online as people buy them on spec then want to return them when they discover its the charger or something else).
